    Dec 2013
    Bobby
    1993 camaro z28 2002 ss clone
    wyandotte mi
    Default can i use these valve springs with this cam?
    so i have a custom grind comp 224/236 502/520 cam with a 114 lobe sep, and im going to be running comp cams .550 lift dual valve springs, is this a safe thing to do? since ill only have .030 before i get coil bind?
    doing this cam swap as youre reading this but taking a break untill after the holidays,
    Mar 2009
    IN
    Depends on the spring pressure also.
    Spring choice usually depends on the lobe the cam is using moreso then just the max lift, but with a mild cam like that you should be fine.
    Just be sure the lift you are using is with the rocker arm ratio you will be running. If that .520" is with 1.5 rockers then with 1.6s you would be .554 and over your springs rating.
    93 Medium Patriot Red Z28: Forged 383,GTP'd AFR 220s(@227ccs), LE .7xx" Billet SR,1.7 Shaftmounts,24x,Maxed Supervic,4150 TB. :12 Metallic Spark Black ZX14R: 1.5" drop, GP slipons, -2 Vortex rear. 152mph trap SWB, stock motor...now with Nitrous... :09 Victory Red LS3 Z51 Vette: Blackouts, muffler delete, sub. Purchased bone stock w/18k mi.
  4. The Following User Says Thank You to Puck For This Post:
  5. #4
    Dec 2013
    Bobby
    wyandotte mi
    right now im using stock style rockers, and i know that lowers the rating a bit, but ill be upgrading to 1.7s whenever i find a decent set for a good price,
  6. #5
    Dec 2013
    Bobby
    wyandotte mi
    heres the specs on my springs, found it on ebay
    Suitable CHEVY 350 SMALL BLOCK
    SBC Chevy 1.44 Dual Valve Springs Retainers Kit V8
    Suitable for
    Chevy 3.5 BRAND NEW
    now AVAILABLE
    SBC Chevy 1.44 Dual Valve Springs ONLY V8
    BIG SPRING HEIGHT 60.52 MM
    WIDTH 36.47MM
    INNER DIAMETER SPRING 27.32 MM
    THICKNESS OF WIRE 4.62 MM
    SMALL SPRING HEIGHT 50.30MM
    WIDTH 24.18 MM
    INNER DIAMETER 17.87MM
    WIRE THICKNESS 3.15MM
    SEAT PRESSURE 110# 1.700%u201D 90#1.750”
    OPEN PRESSURE 325# @ 1.200”
    COIL BIND 1.150”
    .550 LIFT VALVE SPRING
