Page 13 of 21 FirstFirst ... 391011121314151617 ... LastLast
Results 121 to 130 of 203
  1. #121
    The FABRICATOR!
    southern illinois
    Hey Ryan, what flexplate did you go with?
  2. #122
    Mar 2009
    IN
    Buddy had a barely used 153 tci with bolts he sold me cheap.
  3. #123
    Thats what I run, make sure to sand the plating off where the converter bolt heads seat and where the crank bolts seat.
  4. #124
    The FABRICATOR!
    southern illinois
    Oh OK I guess the fti converter will have the 153 tooth flywheel pattern on it? Reason I asked is I've got the lt1 tci flexplate and the stock converter definitely does not bolt up.
  5. #125
    You mean stock 80e converter right? 80e is 11.5 diameter and 60e is 10.75
    The FTI will have the 60e and 80e pattern but with little cuts so the 80e feet fit over the small flexplate.
    Otherwise, like I said you step up to the 168 tooth flexplate and you can bolt both patterns up.
    Sad how much I know on a useless topic.
  6. #126
    The FABRICATOR!
    southern illinois
    Certainly not a useless topic. I still think what's needed in the 80e swap is not fully understood. I know I don't fully understand. A few of you guys that have done it should start a FAQ 80e swap thread. Put some how to's, what ifs, etc in it.
  7. The Following User Says Thank You to firebird_1995 For This Post:
  8. #127
    If you have any questions let me know, got pretty good at installing and removing mine
  9. #128
    Mar 2009
    IN
    Gotcha. I made sure they knew it was for a 153. I was gonna go 164 but I don't wanna buy a new starter, etc. Got a set of arp bolts on the way.
    Ill be full of questions.
    What threads are the cooler lines?
  10. #129
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    http://coloradok5.com/forums/showthread.php?t=268103
    shows the 97 and later trans are different, idk what Jakes uses for there cores but wouldn't hurt to ask unless they have modified it...
    just run a -6 line to the biggest cooler you can run and put a fan on it..
  11. #130
    I ran straight nipples out of the trans housing to -6an pushlok, which fit fine, I wanted to avoid 90* fittings. Then a big ass B&M up front and derale fan unit under car.
    Highly recommend these guys if you can fit em in your budget
    http://www.summitracing.com/parts/jif-200t1/overview/
    Smelly ATF is miserable.
