Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: low idle
  1. #11
    ok ill try that...if i get the idle set right will it hurt driving the car wit iac count down like that
    94 camaro z28- 6pd,cc306,1.6 rr,hurst shifter,pacesetter lts,1le elbow,airfoil,coldair intake,borla,ss hood,98+ ss spoiler,98+ taillights,4.10s,chrome zr1s 17x9.5 & 17x11,nitto 555s
  2. #12
    i was messing wit my car again today and it had warmed up enough to cut the fans on and when they did it dropped the idle even more...what could be causing that?
  3. #13
    Increased load on the alternator.
    The IAC is definitely not responding like it should. Any accessory - A/C, PS - will slow down the engine. The IAC is supposed to open up to maintain the programmed idle speed.
  4. #14
    ok thanks man for all ur info...i will get a new iac then
  5. #15
    Dec 2012
    94 Z28 Camaro
    Texas
    Your a BADASS MUTHAFUKA!
    Sent from my EVO using Tapatalk 2
    94 Z28 TURBO BUILD in progress
  6. #16
    Quote Originally Posted by 94magh View Post
    Did you test the IAC per the Shoebox link I posted?
  7. #17
    Quote Originally Posted by ginoz28 View Post
    Is that good or bad??????????????
  8. #18
    The FABRICATOR!
    southern illinois
    Fred, bad is the new good. Its good to be bad.
  9. The Following 2 Users Say Thank You to firebird_1995 For This Post:
  10. #19
    Dec 2012
    94 Z28 Camaro
    Texas
    It's very good.
    Someday I hope to be a BADASSMUTHAFUKA
