Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Feb 2009
    Lincoln, NE
    Default Oil pump drive gear
    Well my cam ate the drive gear. I am trying to figure out which gear to get now. The GM melonized gear or a composite gear or maybe something better you guys know of? I just want some LT1 guys opinion who have maybe been in my position before I go spending money. Any help would be appreciated!
    The cam looks to be fine. Here are some pics, what do you guys think?
    1996 Camaro Z28 M6
    Custom LE Cam - Bolt on's - DR's
    3.4L to LT1 Swapper
    Oct 2008
    Brian Meissen
    1994 Camaro "Red Alert"; 2022 Camaro LT1 RS
    New Haven, MI
    I don't remember the part number but when my CC503 ate the cam gear I bought an everlast distributor hardened gear from Jegs.
    - Brian Meissen -
    "Magic Man" - LTxTech
    Owner - Michigan FBody Association
    1994 Chevrolet Camaro "Red Alert" [ LT1 Transplant ]
    2022 Chevrolet Camaro LT1 RS "Cherry Bomb 6.2"
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    IMPORTANT ... were you driving when this happened and did you drive very far once you noticed you had no oil psi
    Jan 2010
    Southern NJ
    What gear did you have before and what cam do you have?
    -Joe-
    95 T/A.
    3.4L to LT1 Swapper
    Oct 2008
    Brian Meissen
    New Haven, MI
    When it happened to me I had a stock gear and it was a CC503. It's a known issue where aftermarket cams will "eat" the stock oil pump drive gear.
    - Brian Meissen -
    Dec 2012
    Tommy N.
    Silver 1996 Camaro Z28, Green 1996 Camaro Z28
    El Paso, TX
    How hard is it to change the oil gear drive?
    Nov 2010
    94' Z28
    Yonkers NY
    There easy to change it. Once you get the intake manifold off. OP Get a GM melonized gear. Its what GM suggests useing whenever you do a cam swap. I was stupid and didnt realize that until after my LT1 chewed through 2 came gears. The first was the stock 180k mile gear and the next was the POS! Lunati Everwear. I had the dreaded stamped 13 unit. Which if you do research on was a bad batch from the manufacturer.
    3.4L to LT1 Swapper
    Oct 2008
    Brian Meissen
    New Haven, MI
    Hrm, I have the Lunati Everwear gear in my car now. It's only been a few thousand miles though... hope I don't have issues with that.
    - Brian Meissen -
    Feb 2009
    Lincoln, NE
    Quote Originally Posted by zooguy View Post
    I was just cruising, saw the 'CHECK GUAGES' light come on and I put it in nuetral and costed to a stop and shut if off. I started it 3-4 times after that to check thiings like loose wires and if oil was pumping up to the heads. The last time I started it, it sounded like it had a stock cam. I am guessing the lifters bled out. It ran maybe a total of 2 minutes after I saw the guage read 0.
    1996 Camaro Z28 M6
  10. #10
    Feb 2009
    Lincoln, NE
    Quote Originally Posted by RamAir95TA View Post
    Stock gear with Lloyd Elliott cam.
    1996 Camaro Z28 M6
