Thread: Bullet cams
    Default Bullet cams
    who here is running a Bullet cam spec'd by Lloyd Elliot? just got one. 228/236 .592/.592 w/ 1.6 rockers on a 110 lsa. heard something about their aggresive ramp rates needing a stronger than normal "big cam" spring
    1994 Firebird Formula. Manual.
    Too close to the cities, MN
    I've got a Bullet cam by Lloyd. Using Patriot Gold Extremes -what Lloyd recommended-
    I would give Lloyd a call and ask him what to use.
  3. The Following 2 Users Say Thank You to FormulaJoe For This Post:
  4. #3
    Jan 2013
    1996 Impala SS
    San Antonio, Tx
    Quote Originally Posted by FormulaJoe View Post
    ...........I would give Lloyd a call and ask him what to use.
    Exactly!!!
    Can't go wrong by going that route !
    KW
    1996 Impala SS --- 398ci, Solid Roller Custom Cam, AFR 210 Competition Heads, AS&M Monoblade, Long-Tube headers, Dynomax Exhaust, 4.10 Gears, Eaton Posi
    1995 Impala SS --- 355ci, 52mm TB, Dynomax Exhaust, 3.42 gears, Detroit Tru-Trac Posi
  5. The Following User Says Thank You to KWBaraka For This Post:
  6. #4
    SPRAYED LT1!
    york county, va
    same here, did just what Lloyd said and i'm very pleased.
    Chris Close
  7. The Following User Says Thank You to grn95t/a For This Post:
  8. #5
    gave lloyd a call, should be shipping out the heads by the end of the week with the intake to him. confirmed the cam is a bullet 228/236 .592/.592 on a 110 lsa with a 106 intake centerline. le2 package on a stock bottom end/3200 stall. this is going in thing 1 (father inlaws 94 z28). i will be doing the same package and probably the same cam on a 355/ss3600 stall soon (thing 2: my car). my motor needs a rebuild. nova is now thing 3 which is getting something stupid 383 wise for the street. but since its not gonna be a daily, its gonna be quite obnoxious. too many opti's, not enough time
  9. #6
    Jun 2013
    1996 Trans AM WS6
    NJ
    Lloyd seems like the go-to for this kind of work.
    When I decide to do motor work to my car... I will be giving him a call
  10. #7
    Jan 2009
    Jeff Stark
    1994 Firehawk
    Chi-Town
    Lloyd specd my N/A cam 249/257 .612 107LSA Beehive springs.
    Jeff
    2010,2011,2012, 2013, 2015 LTX Shootout Extreme Street NA Champion.
    2013 Modified N/A runner up. 2015 Mod NA Champ
    1994 Pontiac Firehawk #51 10.82 @ 121mph 1.37 sixty ft.
  11. The Following User Says Thank You to Badhawk For This Post:
  12. #8
    Oh that cam, made it around.
  13. The Following User Says Thank You to shownomercy For This Post:
  14. #9
    NJ
    Well traveled.
    John
  15. #10
    Yeah I heard, well its still in good shape so what's one more time lol
