Page 4 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 89
  1. #31
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    have your tuner pull *4 timing get a WET kit and spray a 75hp shot and your plenty safe and its enough to put a smile on your face
    (and to all the naws pros yeah the rule of thumb is 2* for every 50 shot but if he is wanting to play is on the safe side and not push it more timing pulled then needed is way better than not enough pulled ) with the extra timing pulled you may lose 5-7 hp with out spray but that is no biggie.
  2. #32
    Troy...Im just curious... did u read any of the posts prior?
    Larry (Popo8) Co-owner
    LTXtech.com
  3. #33
    Apr 2010
    Troy
    on this one being honest ... no and i was looking back ... i must have woke up and did some half asleep posting. feel free to remove my nonsense posts.
  4. #34
    Oct 2008
    las vegas
    75 shot 100shot 125shot would be just about the maximum I would put on there.
    There is no special tune to do on that motor to handle nitrous I promise you, many years of nitrous on TPI cars here..
    You can pull timing on your own via distributor
    I use autolite25 plugs gapped at .035"
    Timing set at 6°-8°
    No air leaks in the Plenum boots
    Of course place the nozzle behind the MAF
    Check fuel pressure 44psi w/ vacuum line off
    With a 700r4 I prefer to have a manual activation switch so I can deactivate the nitrous just before the the 1-2, 2-3 shift since some 700r4s get pissed and freak out and not shift in time even during the useless manual shift that people tend to do. Right now if the car is in good shape it should be running 14.8 for an '85 so expect to dip into the mid 13s on a 100 shot
    Sent from my LG-P999 using Tapatalk 2
  5. #35
    Lol
    . thanku man and actually best pass out of three passes with it was a 14.9
    LTXtech.com
  6. #36
    Nov 2011
    Josh
    1991 S-15 Jimmy SLE
    Decatur, Indiana
    lol... got an LS Escalade also...
    Attachment 19020
    LTXtech.com
    TPI, LTX, LSX.... all your missing is a carb 350 for a complete set...... or is that what's in the genesis.....? Lol
    1991 GMC S15 Jimmy
    - 1995 355 LTX- A4, almost AWD
    1997 GMC Jimmy- 4.3 V6 - syty turbo setup
    2012 Kia Rio5- wife's DD
    1990 Acura Integra LS - DD
  7. The Following User Says Thank You to Ghettogmc23 For This Post:
  8. #37
    no.
    . but the cherokee may get one.
    LTXtech.com
  9. #38
    Nov 2011
    Josh
    1991 S-15 Jimmy SLE
    Decatur, Indiana
    no.
    LTXtech.com
    At least with carb the only ports to worry about are on the heads lol!
    btw any update on that?
    1991 GMC S15 Jimmy
  10. #39
    So after the car show today... i threw in 5 gallons of 112... and do i sound nuts if i say its running better...starting better... NOOOOOO wot pinging like i would hear on occassion....
    LTXtech.com
  11. #40
    Nov 2011
    Josh
    1991 S-15 Jimmy SLE
    Decatur, Indiana
    Sounds like timing issues. Knock sensors too tight maybe, or your timing is off at all points which is why the slower burn of 112 helps start and also delays the combustion at wot and gets rid of your pinging. Just a thought.
    1991 GMC S15 Jimmy
