    Jun 2012
    gatlinburg tennessee
    Default wtb staged or puck clutch, keyed crank balncer hub, and crank pully for procharger
    im needing a more heavy duty clutch. not too sure on whats the better options on clutches but needs to rate around 500hp (not quite making that but would rather have more than i need than less). i currently have a fairely new (6,000 miles) basic centerforce and getting slip and wont hold the power. open to suggestions on clutches. Would be interested in clutch/flywheel combo as im still running stock flywheel. Im also looking to buy a procharger crank pully. its a bigger pully only on 5psi on p600b i will get exact size later. and last looking to get a keyed crank balencer hub. If someone has some of these parts theyd sell it be appreciated. Thanks.
    Gretna, Nebraska
    I have a keyed balancer hub for $50 shipped.
    Jun 2012
    have a picture? what brand? Thanks.
    "The Hammer"
    Nov 2009
    JimmyMo
    1994 Trans Am
    In your kitchen, stealing your snacks...
    Honestly I would give competition clutch a call. I had their stage 4 in my last set up, and it was awesome. It's rated for 700 hp I believe. I was making right around 350 at the wheels at the time, and I ran it on a stock flywheel. I think I paid 300 shipped for clutch disc and a new pressure plate for mentioning that I heard of them from a forum. I can't say whether another clutch is better for the money or not, I haven't run anything else.
    "Only in the Corps can you put three guys in a room with an anvil and a rubber mallet, come back 15 min later, and the anvil is broken, the rubber mallet is missing, and nobody saw a damned thing!"
    Jun 2012
    Will the stock balencer work with this?
    Canda, BC
    Quote Originally Posted by 94Blackbird View Post
    Where did you find a stage 4 from them for an lt1?
    Gretna, Nebraska
    Its just a keyed stocker. I think thunder racing had them machined if im not mistaken. yes you can use a stock balancer with it because its just a stock modified hub.
