02-17-2013, 10:38 AM #1
Shift points from 4000 stall to 3600 w/N20
Hey all...I am changing stalls and I am not sure but I think I am going to need to change my shift points. Is this correct? Is there a lot to this? Thanks
97 Mystic Teal Camaro, Forged 396 Single plane EFI 24x N20, Finishline 4L60E, S60, M/T Drag Radial
02-17-2013, 10:20 PM #2
Not hard. What are you using for programming?
1994 Camaro Z-28 M6
LE 242/248 cam,Crower split ratio rockers,AI 23*Trick Flow heads,JetHot longtube headers,Borla exaust,ewp,pro5.0,hybrid TNT wet kit.
02-18-2013, 01:54 AM #3
- Jul 2012
- SouthWest Minnesota
- 244
I have LT1 Edit and it is normal shift mode vs tps % for the table. Might be shift vs VSS I hav seen for a table also in other programs.
97 Comp T/A #161 out of 164 LT1 383 stroker, TPIS/AFR heads, JE pistons, 9.3cr, extreme energy comp cams 224/230, Howards billet rods 5.85, Callies dragon slayer crank, 2 bolt mains converted to 4 bolt billet, Mildon oil pump, MSD opti, 6AL, boost retard, HVC 2 blaster coil, BBk 58mm, 50lb injectors, 3200 stall. Took 600b off to help fund twin turbo.
02-18-2013, 07:17 AM #4
02-19-2013, 01:15 AM #5"The Rock"
See the tuning section where i am offering tobhelp members.
Larry (Popo8) Co-owner
LTXtech.com
