Page 1 of 30 1234511 ... LastLast
Results 1 to 10 of 297
Thread: My Turbo Build
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    Utica, NY + Jacksonville, FL
    Default My Turbo Build
    Engine:
    Forged 355
    Eagle 4340 crank (3.48'')
    Eagle 4340 5.7'' rods
    billet 4 bolt mains
    SRP, forged pistons, 24cc dish
    JE piston rings
    Hot tanked
    align bore
    machine maincaps
    bore/hone .30 over
    neutral balance assembly
    bearings( fed mog mains, m77 rod, duraband cam)
    Canton oil pan
    Comp Custom Grind Turbo Cam
    Stock:
    Heads
    Intake
    Fuel:
    Racetronix/Siemens 63lb injectors
    Fastbird's Custom Fuel Rails
    Custom Double Pumper (dual 255s, -8AN feed, -6AN return)
    Aeromotive Adjustable Fuel Pressure Regulator
    Electronics/Spark:
    Stock Opti for a few months, then LS1 coils and Megasquirt II
    PCMforless initial tune then custom tune..
    NGK TR6s
    Stock PCM
    Turbo:
    e bay 12”x4”x36” air to air intercooler
    Tial 50MM BOV
    REALQUICK hot parts
    Custom Log Manifolds
    All mild steel (except the Vband clamps)
    Pass. side log - 1.75" primaries and 2.5" log
    Crossover: 2.5"
    Driver's side log - 1.75" primaries and 3" log
    Downpipe - 3"
    Tial 44mm Wastegate
    TC78 F1 Trim turbo
    Note:
    The motor with the turbo kit mocked up is not mine, it is the guy's who I bought the kit off of on Camaroz28.com
    -Ryan
    93 Z28 M28
    Mod List
    nice... so let me get this straight is it single or twin turbo???? Cause I see one turbo on one side but I don't see the other one and the exhaust goes backwards......
    West Coasts Fastest OEM block 4th gen
    9.06@153.8 1.35 60', 10.62@127 all motor
    CSM Racing Engines 383, SR, single plane, etc!!!!!
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    It is single, there is a crossover pipe that can't be seen in the pictures that merges the passenger side with the driver's
    -Ryan
    93 Z28 M28
    Mod List
    Founding Member
    Fort Worth,Tx
    very nice! cant wait to see it running and the numbers it puts down.
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    Im looking to have it done by March (hopefully). I'm expecting 500 on 10psi.. and close to 600-650 on 15psi.. the 15 will only be run on occasion, 10psi will most likely be my cruise around setting.
    Because of my compression, I'm hoping that race gas won't at all be necessary even at 15psi. And also because my block is not o-ringed, I don't plan on going over 17-18 EVER.
    I might end up keeping my stock block to build up to a 383, but with the amount of money I'm spending on the 355, I doubt I'll end up doing that
    -Ryan
    93 Z28 M28
    Mod List
    Founding Member
    Joplin, MO
    That's going to be a pretty sick ride, man. Definately keep us posted.
    1997 Camaro Z28
    Lots of visual horsepower, full bolt-ons, and a little spray....
    Quote Originally Posted by quik95lt1 View Post
    yea so back to the tune..........do what i said before you make yourself a paperweight lol
    MA
    That kit should make great power! My welds are 100% better now on my newer stuff (built that kit awhile ago). That same designed alreay made 574rwhp @ 11psi on a load bearing dyno by one of my other customers.
  8. The Following User Says Thank You to RealQuick For This Post:
  9. #8
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    Yea I think I'll be content with 600whp especially because with my compression, I should have room to grow.
    Jon, I sent you a pm on cz28 asking you some questions(my s/n is Pyrodawg on there)
    -Ryan
    93 Z28 M28
    Mod List
  10. #9
    Chicago, IL
    Blog Entries
    3
    Those are some really good progress pictures. Looks great!
  11. #10
    MA
    Shoot me an email: jon@lt1boost.net and I'll reply back to it with the details.
    96 TA WS6 - 383ci + T76 = no traction
    www.lt1boost.net ... your home for LTx turbo kits
