Results 1 to 10 of 14
Thread: Ran a new PB!!!! 10.53 at 130.45
06-08-2012, 10:48 PM #1
I couldn't hook worth shit though. I tried 9lbs, 11lbs and 13lbs in the tires, same result every pass, but broke 130 every time. Previous highest mph was a 128.70.
Ran a horrid 60 ft but recovered good and pulled strong:
Right lane:
06-08-2012, 10:54 PM #2"The Rock"
THats awesome.....
Was the traction issue TRACK PREP?
or lack there of.....?
06-08-2012, 10:56 PM #3
No clue. Probably on my end. When other guys are yanking the wheels, then I can't make any excuses, lol. I'll figure it out though. I did add some weight to the nose so that never helps.
06-08-2012, 11:04 PM #4
- Oct 2008
- las vegas
- 1,721
Awesome congradulations bro!
Sent from my LG-P999 using Tapatalk 2
06-09-2012, 07:37 AM #510 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
Damn nice mph, I've found rear shock settings make more difference in 60' than tire psi. Whta opti are you using and how high are you spinnin it?
-Josh
co-owner of BDBRacing.com
NMCA OC 9004
06-09-2012, 09:28 AM #6
MSD vented and I'm shifting it just before 7k. Literally as high as it will go. The motor wants to go to 7300 or 7400 I can feel it by the way it pulls, but I'm still running the factory pcm. I have generic Comp Engineering shocks, with no real adjustability. Time for some AFCO's from Madman.
06-09-2012, 09:45 AM #7Long Live the Opti
Nice man, loving that trap speed.
06-09-2012, 12:14 PM #8
- Nov 2010
- North Port Fl
- 264
Your car is badass!! I know you want to go to a aftermarket computer but do you think it would go faster with the stock ecm and a smaller cam? I think 9's N/A with the stock computer would be crazy. Not sure if anyone has done that.
06-09-2012, 12:47 PM #9
nice.
97 firehawk m6 with a forged long rod 355 stock heads and intake soon to be upgraded to LE 21* tfs heads and a big asscam , rpm built level 5 t56 trans s60 with 4.30 gears umi suspension walbro pump and hot wire kit and a spinning best 12.36 @ 114 crap 60 foot.
06-09-2012, 01:25 PM #10
Ben Moore is the only one that I know of that has run a 9 N/A on a stock computer but he did it on one of those mineshaft air days in the late fall. It wouldn't run 9's all year. His car was a 10.15-10.20 car most of the time.
RPM is everything. If I could spin it higher, I could ditch these 3.73's and get some 4.30's and a 28" tire. More contact patch and more overall gear. It would get the car up and moving faster and still be able to carry the same topend. My cam isn't too big considering the cubes I have to feed.'94 coupe, 10.15 at 133.65 414" LT1, 4500 stall, n/a, pump gas, mufflers, street trim
