Results 1 to 3 of 3
    Jan 2009
    Tucson, AZ
    Default Door Panels, Shifter Plate, Center Console and more
    Camaro Door panels - anything but tan will be considered.
    93-96 Charcoal/Gray Center Console - I would prefer the lid to be working. It also needs to be for a manual (I think the only difference may be the shifter plate).
    93-96 6-Speed Manual Shift Plate - this is the part that holds the shift boot.
    If someone has an entire manual center console, that would be even better.
    *CAN A MOD MOVE THIS TO THE WANT TO BUY SECTION*
    ThatAdStudent.com - Advertising and Graphic Design Blog
    1993 Camaro Z28 M29 - Down for Repairs and Upgrades
    How much for the 6 speed shift plate?
    I have a lid if you end up needing one. The hinge part is broken, but it looks like you can make your own hinge in that area..
