Thread: cam help
03-09-2011, 11:30 PM #1
- Jan 2011
- 14
cam help
What would custom grind cam of 227/236 535/535 do in power for me sinse i have stock ported heads with 1.6rr beehive springs hardened pushrods guideplates, pacesetter longtubes with 2500 stall and 3.73 gears? Also would i be better off going with a lsa of 112 or 114? Thanks
03-09-2011, 11:33 PM #2
You would be better of going with neither LSA...
You need way more stall
That cam will probably make average mid to top range power. Nothing outstanding.
What are the .006 and .200 duration numbers.
-94 Z28 355 M6 24X E-85 21* TRICKFLOWS TH400 S60
C5 Z06 IN ROAD RACE TRIM. COMING SOON
03-10-2011, 05:21 PM #3
- Jan 2011
- 14
I changed my cam chioce to a 224/230 536/550 114 lsa would my stall be ok with that or should i upgrade my stall
03-10-2011, 10:46 PM #4
the wider lsa is going to make it WORSE down low and in the midrange.
PRO-JECTIONENGINEERING
Custom Wiring Solutions LTx Oil Pressure Savers 24x Harness Conversions
Proudly a veteran owned business!
Please PM or EMAIL for info/ordering while our website is under construction!
Race in the Extreme Street N/A class at the 2011 LTx Shootout for a chance to win a FREE 24x Harness Conversion!
03-11-2011, 01:40 AM #5
Where did you come up with those numbers?
What are all your other mods? Someone cant possibly give you accurate advice on the cam without knowing all the other details of the car.
But yes if you're trying to "bandaid" the stall the wider LSA is going to move the torque peak higher in the rpms...
You're going the complete wrong way for the typical small block. Something requiring a 114 LSA on a N/A application better have a SHIT LOAD of compression, for starters.
