Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Lifter Pre-load
    Macomb, MI
    Default Lifter Pre-load
    Just wondering what you guys think is the optimal lifter pre-load for stock lifters (pro-mag rockers). Right now I have my lifters adjusted at 1/6 of a turn pre-load, and im paranoid that might not be enough. Been driving it that way for about 1000 miles and it definitely has the "sewing machine" sound from inside the car... but ive heard this is perfectly normal.
    I might be going to the track this saturday (and hopefully get my tune somewhat dialed in). I dont want to collapse a lifter if i can help it haha.
    opinions?
    - Joel - 95 Z28 M6
    "It's an ingenious solution to a problem that should never have existed in the first place!"
    Bethel, Pennsylvania, United States
    I always ran 1/4 turn, it ran better at 1/4 than it did at 1/2 on mine. most people say 1/2 but it was to much on mine. 1/6 isnt enough tho.
    93 TA, 383 stroker, ATI procharger, Accel DFI Gen VII, TH400 RMVB w/Tbrake, narrowed moser 9 inch.
    Don't overtighten; zero lash + 1/4 is as far as you want to go.
    Lifters "pump up" as RPM increase, which will cause the lifter preload to battle against
    the spring pressure, which leave valves open at high RPM.
    That can mean loss of power at the top end or worse .... BANG BANG BANG.
    The "sewing machine" sound is normal.
    LTx Mod, Founding Member
    Saugus, MA
    1/4 on mine, sewing machine too. Stock lifters/GMPP 1.6 RRs/Hotcam/LT4 springs with all the LT4 goodies (obviously).
    Runs balls to the wall up top though, no problems here.
    Nick
    - 2003 SVT Cobra T56/4.6L - Pullied, Tuned, Full Intake/Exhaust, Stg3 Clutch (29k) - 483rwhp @14-15psi
    - 2002 Ford F350 7.3L Powerstroke - Edge Evo II/33" BFG AT TAs/4" MBRP Turbo Back + Intake (164k)
    - 1995 Pontiac Firehawk #224 (Chameleon) - Full Bolton/Cammed/Full Suspension (71k) - 12.75 @ 107.94
    http://www.fquick.com/Fixxer777
    Pr0jekt Turb0?
    Ryan
    1993 Camaro Z28
    Utica, NY + Jacksonville, FL
    i think i set mine to 1/4 it was either that or
    3/8 (1/4 + half of 1/4)
    i have chromemoly pushrods, crane 10308 springs, ls7 lifters, and promags
    I have never heard my valvetrain quieter than it is after this adjustment
    -Ryan
    93 Z28 M28
    Mod List
    Saugus, MA
    Yeah 1/2 is a little too much I think, somewhere in the area of 1/4 is fine....
    Nick
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Stock lifters I'd go 1/2 turn past zero. IIRC factory called for 1/2-3/4 turn.
    Macomb, MI
    should i bother re-adjusting from 1/6 to 1/4?
    I was thinking about trying the engine running method to save me a lot of time.
    - Joel - 95 Z28 M6
    centerville,ohio
    I've always set mine at 3/4 turn.
  10. #10
    My engine builder absolutely swears by just barely taking out the "noise". He basically goes to zero lash and then, maybe like 1/20th of a turn, no more than that. You CAN run into problem at really high-rpm if you have them too tight.
