Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: driveshaft mod
    Daily Driver
    Tuscaloosa, AL
    Default driveshaft mod
    Above 120, my gear shift vibrates like crazy. Is this because of the stock driveshaft? Would an aluminum or CF one get rid of this vibration? What about an LS1 DS?
    95 T/A M6
    Bolted | Slammed | 4.10s
    Chi-town area
    LS1 Alum made a world of difference on mine! Bought it used for 75 bucks in mint shape.
    Mikie
    www.elliottsportworks.com www.speedinc.com
    Bedroom built 355!!!!!!!!
    Daily Driver
    Tuscaloosa, AL
    Quote Originally Posted by AChotrod View Post
    ebay? the LS1 alum ds just bolts right up?
    95 T/A M6
    I was thnking aboutpicking up an ls1 ds is it worth it?
    1997 Camaro SS
    Overland Park, Kansas
    Or you could have your driveshaft balanced.
    LS1 DS is lighter.
    Steel is stronger.
    -Eric
    1997 Camaro SS # 2703 - Full exhaust, brand new suspension, bolt-ons, etc.
    2004 Silverado
    Z71 - Airraid, Corvette Servo, 33" AT's, leveled, etc.
    Oct 2008
    Fort Wayne, In
    Yea getting your stock driveshaft balanced will work fine. You save some rotating mass by going to the ls1 shaft, but its not as strong. You should not have any problems either way.
    !996 z28, m6, 42,000mi, 383, H/C/I, full bolt on's(sold)
    2000 Buick Regal GS, 79,000mi, 3.5 pulley,
    3" off road DP, PEM, Gutted Airbox, ZZP 1.0.
    Oct 2008
    Colorado
    If you plan on not modding any more than LS1 DS is the way to go , but if you want to keep modding and get some power out of the LT then have your balanced, like they said they are stronger.. I know i don't want to see what a drive shaft looks like coming through the floor board, do you?
    Houston
    Hey, once you go that far you should have a driveshaft loop... right?
    -Duane-
    1994 S-10 - Lt1/700r4 - project /// 2001 2dr Blazer - boring daily
    Daily Driver
    Tuscaloosa, AL
    a DS loop could save your life.
    i don't know why but i never thought of getting the stock one balanced..
    i've never heard of people breaking the aluminum ones.
    how much lighter are the aluminum ones? light enough to feel it? i.e. better 60' times?
    95 T/A M6
  10. #10
    Central Florida
    I had an LS1 shaft in my car....until it spit out in 3 pieces one night. I'll see if I can find the pics. After seeing the gauge of the aluminum used for the LS1 DS I would never put one back in my car. An automatic might get away with it but us manual guys are always going to shock the driveline harder and I just don't trust an LS1 DS to take the abuse anymore. The 1LE shaft is also aluminum and is a heavier gauge. If you want aluminum go 1LE. If you want strength, go with a Denny's N20 shaft...at least that's what I did.
