Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Default TunerCat help needed.
    I just downloaded Tunercat 2.21 and am trying to get it to let me get to changing some constants. But I don't know how to get the thing to work. Can anyone give me a walkthrough of how to set up Tunercat to start programming and how do you flash the new file onto the car?
    1994 Camaro Z28 A4 - 357ci, CC306, 918's, ProMag 1.6 NSA, GM guideplates, chromoly PRs, LS7 lifters, Granatelli MAF, ACCEL Coil, CAI, Pacesetter LTs to 2 1/2" true dual mufflers, 4:11, tuned by PCMforLess and modded by myself, !AIR, !EGR, turning till 6000 on stock shortblock
    Pr0jekt Turb0?
    Online
    Ryan
    1993 Camaro Z28
    Utica, NY + Jacksonville, FL
    Quote Originally Posted by twcblackhand6970 View Post
    you need to have at least an initial file on it to mess with the settings
    Mine is a little different and I have to burn the chip.. somehow you have to get a stock .bin file or at least whatever tune you have on your car right now. Wish I could help more but I only know how to do it with a chip reader/burner
    -Ryan
    93 Z28 M28
    Mod List
    Well it has a Asdz.bin file already on it, I just don't know if that is car's computer.
    Pr0jekt Turb0?
    Online
    Ryan
    1993 Camaro Z28
    Do you have the ASDZ label on your pcm/ecm anywhere
    -Ryan
    93 Z28 M28
    Mod List
    Pr0jekt Turb0?
    Online
    Ryan
    1993 Camaro Z28
    http://monodax.com/forums/tunercat-f...tock-file.html
    there are some in there i believe
    -Ryan
    93 Z28 M28
    Mod List
    Jacksonville, FL
    just upload the current tune you have on your car.
    1994 Camaro Z-28 M6
    LE 242/248 cam,Crower split ratio rockers,AI 23*Trick Flow heads,JetHot longtube headers,Borla exaust,ewp,pro5.0,hybrid TNT wet kit.
    yea, i did that. i didn't notice that the $EE wasn't installed so I installed it and got my .bin file. changed some constants and now it shifts right.
    ok, now how do I know if I'm running rich? I use TTS right now and it says my BLMs are 128, but I'm in open loop due to bad o2 which I'm about to fix. Is that BLM correct or not cause it's in open loop?
    nvm, tunercat killed pcm ....gave me error as it was programming and poop now. just order madz28 tune, lets see how this stuff goes.
  10. #10
    Houston
    Is that a common problem? I'd like to start tuning mine.... but don't want to mess it up having no clue what I'm doing.
    -Duane-
    1994 S-10 - Lt1/700r4 - project /// 2001 2dr Blazer - boring daily
