Results 21 to 26 of 26
09-29-2008, 04:33 PM #21
My Th400 cost me a lot more than that but its a pro built trans that will handle 1000+ HP,
Trans------ $1500 RMVB w/trans brake, Alu trans pan,
Converter-- $780 ATI Tree master MRT custom converter
Trans cooler- $150 HD cooler with built in fan
crossmember- $170 BMR tubular
Speedo reluctor-$40
speedo sensor--$70
ARP flex bolts---$11
ARP converter--$ 8
SFI flexplate--- $60
B&M shifter----$200
Cro-moly shaft-$600
Total---------$358993 TA, 383 stroker, ATI procharger, Accel DFI Gen VII, TH400 RMVB w/Tbrake, narrowed moser 9 inch.
09-29-2008, 04:51 PM #22
i just dropped 2000.00 with ati for my th400 rmvb and blown/fuel converter. 300.00 for a strange drivestaft and 180.00 on the crossmember. can't wait to get it in the t/a and hammer it through the gears a few times! drove my friends 94 z28 with almost the same set up ( different converter ) and man what a blast to drive!
Chris Close
10-07-2008, 02:15 AM #23
700R4 here as well, ill go 6 speed when this trans takes a dump.
I should be around 700rw on gas, I doubt the trans will last, but im sure itll hold a few 9 second passes.Building the LTgun.
10-08-2008, 02:09 AM #24
Talk to these people here.http://www.rosslertrans.com/Transmission%27s.htm .Good place to getting answers to your Questions. All of the trannys listed.Plus one no one has mentioned the 200. All have there place in fast/race/street cars.The Power glide is pretty much the mule/work horse of the trannys been around a very long time. With a lot of options and prolly the lightest of all the trannys. Check this link out lots of great old school info on the glides th400/th 350.http://www.442.com/oldsfaq/oftrn.htm.
10-08-2008, 09:51 AM #25
12-20-2011, 04:38 PM #26
i know im bringing up an old post but does everyone just use the brackets that relocate the torque arm?
