Results 1 to 6 of 6
04-26-2015, 10:12 AM #1
- Apr 2015
- Tim Schutt
- 94 Camaro Z28
- Chicago
- 3
Trans pressure tables with 58mm TB
Looking for advice as to what people have done in their trans tables to compensate for a 58mm throttlebody.
I'm running a Cahall "race" build 4l60e and after installing the new 383 with a TPIS 58mm throttlebody I can feel that the low throttle shifts seem softer.
I'm running on a base tune from Solomon at this point and as far as I can tell all he has done for that was to bump the pressure up 3 points at the 0% throttle position.
04-26-2015, 10:41 AM #2
LTXTech Sponsor
- Feb 2013
- 1998 Trans Am
- Greenville, SC
- 147
I would add another couple pounds of pressure (2-3) at lower speeds if you want to firm it up a little bit. With any built transmission, I do not recommend touching WOT values as the valve body/valve body components are usually modified to make best use of the stock pressure settings. Sometimes builders will be specific on changing this, other times not. Part throttle stuff really just depends on the shift quality and how firm you want it. I try to make smooth pressure ramps that allow for comfortable everyday driving shifts, then firm, positive shifts when getting after the car.
1998 Bright Green Metallic Trans Am LS1/M6, Cam/Intake/Exhaust, Full Suspension, 3.42 gears, 30 MPG highway and 397 RWHP on untouched heads, 12.47@115 mph.... needs gears!
2011 Victory Red Silverado 1500 Z71 LC9 5.3/A6, Z71 appearance package, factory 18's, e85 warrior
Owner of Mickelson Performance, offering affordable LTX Tunes - mickelsonperformance@yahoo.com - www.facebook.com/mickelsonperformance
The Following 2 Users Say Thank You to sweet-94z28 For This Post:
04-26-2015, 02:49 PM #3Administrator
- 7,693
With franks trans I wouldnt go too far on changing the mids, what did you tell him for your shift firmness when he built it?
04-26-2015, 05:20 PM #4
- Apr 2015
- Tim Schutt
- 94 Camaro Z28
- Chicago
- 3
I told Frank what ever he thought was best with the firmness. 1/2 shift was almost bonejarring and the rest just felt nice and crisp at all throttle positions.
My idea is to start with bumping everything up 3 lbs, up until the 18.5% tps in the table. Seems like everything above that feels fine.Last edited by Thumperbass; 04-26-2015 at 05:36 PM.
04-27-2015, 06:39 AM #5
Did you confirm the TPS voltage at idle and wot?
04-27-2015, 07:50 AM #6
- Apr 2015
- Tim Schutt
- 94 Camaro Z28
- Chicago
- 3
Still working on fine tuning tps and idle, but yes I'm getting the full range from it.
