Page 14 of 21 FirstFirst ... 4101112131415161718 ... LastLast
Results 131 to 140 of 203
  1. #131
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    I ran straight nipples out of the trans housing to -6an pushlok, which fit fine, I wanted to avoid 90* fittings. Then a big ass B&M up front and derale fan unit under car.
    Highly recommend these guys if you can fit em in your budget
    http://www.summitracing.com/parts/jif-200t1/overview/
    Smelly ATF is miserable.
    didn't you y block yours and return them into a y back into the trans? had any good amount of street duty to see temps?
  2. #132
    Quote Originally Posted by dawdaw View Post
    Yes, but, I am not 100% on those temps now.
    Exhaust dump melted connectors so they were getting hot externally.
  3. #133
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    are you dumping the exhaust right at the k member?
  4. #134
    I was, aimed it by accident at the trans, so the trans temp sender I think got some external heat projected at it.
  5. #135
    Mar 2009
    IN
    I have a hose barb 11x10x3/4" and a -6an 10x7x1.5" here. Opinions?
  6. #136
    Go fittings, hose barb and hose clamp is rigged IMO.
    MVB means high line pressures, don't cheap out.
  7. #137
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    With a manual valve body 4l80 can you run some form of aftermarket shifter? or using a stock one?
  8. #138
    Yea, any gate/rachet shifter will work as long as you get it setup for a 4 speed.
  9. #139
    JeremY
    1972 NovA
    Elsberry, MO
    True Street better watch out!
    From what? You working on your ride on the trailer too close to the staging lanes?!
    Hoping to see it run like a "Champ"
    This year.... But not a "King!"
    '72 Nova "HadeSS"
  10. The Following User Says Thank You to JCzNova For This Post:
  11. #140
    Mar 2009
    IN
    Gotcha. Think the an cooler is big enough?
