Results 1 to 3 of 3
    LTX Regular
    May 2019
    DARREN BRANDON
    1983 jaguar xj6
    Default Ac compressor hookup question for the swappers...
    For anyone that followed my threads, I have a 94 lt1 in an 83 jag, I have been running the ac without issues, although due to wiring etc, compressor is still run via jag wiring and relays etc, being as the lt1 setup has no low pressure switch, I am currently running compressor with no switches installed, I have found a compressor mounted low pressure switch and will install it, however, I donít know which of the two plugs on the back I should replace with the switch,, internet search hasnít turned up much, other than prices on compressors..... hopefully one of the gurus here will know!!
    thanks in advance,
    Darren
    LTX Regular
    May 2019
    DARREN BRANDON
    1983 jaguar xj6
    A picture is worth a thousand words... lol
    This is a spare compressor I have pulled one of the plugs to double check switch will fit, but here are the ports!
    Eh
    Quote Originally Posted by Darrenmb View Post
    i believe the top one.
    2021 Durango R/T Tow-n-Go
