Originally Posted by
Fastbird
FWIW I DESPISE that method. Waiting to feel drag when spinning means you've got enough preload on them already to cause drag while spinning. You're past zero lash at that point already. Lift up and down until you have no play, then set lash past that. Very possible lifters are too tight.
Also, pulses from opti for injectors is good, but you need to verify the injectors are firing. The PCM fires the injectors by grounding the circuit. Could be a PCM issue, injector harness issue......shoot, have you checked the 7.5a injector fuses? That caught me once. Grab a NOID light and hook it up to see if you're actually getting injector fire signals too if those fuses are good.
