I am going to be selling my car soon but need a few parts to prep it.
Gear indicator that reads P,R,N,D,3,2 (like the one in the picture)
Driver's door door handle bezel
Factory shift knob
Attachment 38192
Factory shift knob
Attachment 38192
headlight gear can just disconnect it, manually rotate it 180 degrees with a screwdriver, and reattach. only half the gear strips, then u use the other half
I will definitely do that! You da real mvp
Still need a few parts.
Small vent cover (See attached picture)
Driver's side window motor/regulator
I'll even buy the whole section of the center console if I need to as long as it has the right gear indicator plate
bump. Still need everything except the alternator
Awesome! let me know.
updated list!
I have the vent, door bezel and shift knob...I'll check the conditions tonight.
Awesome! I already got the vent. For some reason it wont let me delete that picture. I could definitely use the bezel and shift knob.
bump
I've got a spare A4 shift knob, if you still need it. Came off my z28.
what shape is it in?
Really good shape. I could text a pic of it to you if you want?
