Hey guys I was wondering if it's possible to swap over my ugly yellow 93 gauges ac controls windows switches etc to the white 94 ones. Will there be any problems I would run in to also would everything work and a line up
I know you can swap gauges (I have a 97 cluster with the digital readout in my car). Pretty sure you can swap all the rest of the window switches, A/C controls and stuff too. It's all pretty much the same.
With the gauge cluster swap, you can use 94-97 only. 98 or newer won't read most of the gauges right. Also, in order for your tach to work, you MUST use an aftermarket ignition box. I've found zero way around this. No box, no tach, plain and simple.
97s +had digital odometers
LTXtech.com is my DRUG!
onlu the odometer is digital. And Idk.. looks like thats what theu are sayin above
Yeah, starting mid year in 97 the odometer and trip meter went to the digital readout instead of the old school rolling numbers. Yes they're plug and play on 94-96 cars and work fine on 93's so long as you're running an aftermarket ignition box.
Posted from my LG G2
