Originally Posted by
dawdaw
set the front shocks to full loose on the extension, and halfway on compression , rear close to full stiff on compression, extension halfway.. on a radial car you NEED to have good weight transfer to the rear tire... play with the spring height up front. lca 1 hole from the bottom hole, you don't want to much antisquat.
you don't want the car to squat at all, make sure pinion angle is good , and the suspension front to back is free and not binding anywear. tire pressure looks good. this is a stick car? if so might want to entertain thoughts of getting some et drags or et street bias plies, radials will work but you will have to have the suspension absolutely perfect and the radials will not recover like a bias ply will.
Let us know how it goes. btw what's the details on the whole car?
