i'm puttin my headers on on my 94 formula. I need the flat style o2 extentions right?
look at the o2's you pull off. i think you have the sqaure ones. someone will chime in and tell ya. im not sure. thought 96 and 97 had flat. are you putting in LT , shories? i just did mine and let me tell ya. do everything right the first time! DO NOT go cheap and short cuts!!! i know, im dealing with them now and it sucks
im not sure about the early years,i know the later model ones had the flat 4 pin style if they have 4 wire 02's
My 94 had the flat style, and my 97 has the square.
I bought my extensions from SPEEDINC which is a wonderful sponser to this site. :)
ok. i got the flat ones from speedinc, so hopefully it is the right one
I'll elaborate on that. One of the header O2 sensor harnesses should reach (driver side I think). The other will need either a 12" or 18" flat connector extension. I'd recommend the 18", more slack to work around the primaries.
For 96 and 97 cars with after-cat O2s, you will need one 24" square connector extension. The other will reach.
