Fastest LTx List...Lets get it started!
Posting times is fine but lets get the list going. Always give you something to shoot for this summer. :secret:
In order to be added to the list please post your times and any updates in the list format. Times posted that are not in the format will not be added until they are changed.
Also add @Sahara54 to your post for me to be notified.
Thanks.
#XX Screen Name-
1/4 et - PA/NA XX.XX ~ 1/4 mph - XXX.XX ~ 1/8 et - XX.XX ~ 1/8 mph - XX.XX ~ 60ft - X.XX
Car (example 95 Z28) ~ Engine Size ~ Transmission ~ Rear end ~ Gears ~ Extra info
Now on to the list!!!
#1 Tony Shepherd
1/4 et - PA 8.45 ~ 1/4mph 161.57 ~ 1/8 et 5.43~ 1/8 mph 130.37~ 60ft - 1.29
93 Camaro Z28 (N20)
#2 SSmity
1/4 et - PA - 8.501 ~ 1/4mph 158.06 ~ 1/8 et - 5.42 ~ 1/8 mph 128.70 ~ 60ft - 1.227
94 Caprice ~ PG ~ 300 NX 2 Stage Plate ~ 33x16.5x15
#3 Ponyhntr -
1/4 et - PA - 8.503 ~ 1/4mph 155.53 ~ 1/8 et - 5.527 ~ 1/8 mph 133.70 ~ 60ft - 1.398
96 Camaro Z28 ~ A3 ~ ProCharger F1A ~ Q16 ~ Moser M9 ~ 3.89
#4 Milehighz28
1/4 et - PA 8.70 ~ 1/4 mph - 156.88 ~ 1/8 et - 5.58 ~ 1/8 mph - 126.76 ~ 60ft - 1.36
93 Z28 76mm Turbo~ 355 ~ Powerglide ~ 12bolt ~ 3.42
#5 Slammed98gmc
1/4 et - PA 8.72 ~ 1/4 mph – 156 ~ 1/8 et - 5.62 ~ 1/8 mph - 125 ~ 60ft - 1.32
1998 GMC Sonoma ~ Hughes Performance PG ~ Hughes 5000 stall~ 8.5 10 bolt ~ 3.42
#6 JakesZ28
1/4 et - PA 8.957 ~ 1/4mph 151.6 ~ 1/8 et - 5.742 ~ 1/8 mph 122.46 ~ 60ft - 1.349
94 Camaro Z28 ~ glide ~ ptc converter ~ fabbed 9" ~ 3.89
#7 8SEC6SPD
1/4 et - PA 8.97 ~ 1/4mph 155.23 ~ 1/8 et - 5.80 ~ 1/8 mph 123.28 ~ 60ft - 1.349
96 Camaro SS ~ EFI ~ Liberty's M6 ~ Mcleod ~ Moser ~ 3.89
#8 Jason Brisson (OutlawZ)
1/4 et - PA 9.06 ~ 1/4mph 153.8 ~ 1/8 et - 5.76 ~ 1/8 mph 122.1 ~ 60ft - 1.35
95Z28 ~ TH400 ~ ATI 4400 stall ~ 9" ~ 3.89
#9 slow lt1
1/4 et - PA - 9.45 ~ 1/4 mph - 140.61 ~ 1/8 et - 5.97 ~ 1/8 mph - 113.64 ~ 60ft - 1.31
1995 Z28 ~ th350 ~ BTE-4200 ~10-bolt ~ 3.73
#10 SnakeKilla
1/4 et - PA – 9.70 ~ 1/4 mph – 136.97 ~ 1/8 et – 6.22 ~ 1/8 mph – 110.57 ~ 60ft – 1.37
9X Trans Am ~ TH-400 ~ Converter? ~ Rear end? ~ 4.10’s
#11 halfasshotrods
1/4 et - PA- 9.75~ 1/4 mph - 138~ 1/8 et - 6.25 ~ 1/8 mph - 112 ~ 60ft - 1.44
94 Z28~383~F1 Procharger ~TH400 w/ brake~4500 stall - 9"~370 gears ~3700lbs
#12 FUEL
1/4 et - NA - 9.775 ~ 1/4 mph - 136.59 ~ 1/8 et - 6.193 ~ 1/8 mph - 110.22 ~ 60ft - 1.379
94 camaro~ th400 ~ 3800 j&w ~ moser 9 ~ 370
#13 - Ray@Nitrodaves.com
1/4 et - PA - 9.826 ~ 1/4 mph - 132.02 ~ 1/8 et - 6.303 ~ 1/8 mph - 111.83 ~ 60ft - 1.424
94 Formula ~ 700r4 ~ Goebel 3800 stall ~ 12 Bolt ~ 3.73 ~ 3220# ~ 200 shot
#14 Twisted Z
1/4 et - PA - 9.827 ~ 1/4 mph - 137.37 ~ 1/8 et - 6.266 ~ 1/8 mph - 110.51 ~ 60ft - 1.414
SSEFI 380 LT1~ SSEFI 3L80~ A-1 4~4000 stall ~Nitro Dave's MM .088 jet N2O,~3.73 12 bolt~3420Lbs
#15 Speed Inc (Larry)
1/4 et - PA - 9.85 ~ 1/4mph - 138 ~ 1/8 et - 6.29 ~ 1/8 mph - 110 ~ 60ft - 1.41
97 Z28 ~396, SI H/I, LE H/R, FLT7 w/SS3600, S60 w/ spool & 3.73
#16 SSlowBoat-
1/4 et - PA 9.905 ~ 1/4 mph - 133.3 ~ 1/8 et - 6.245 ~ 1/8 mph - 109.86 ~ 60ft - 1.266
94 Firebird - 381 Solid Roller - Turbo 400/ FTI SST 9" Converter - S60 4.10 gear - 275/60/15 ET Street R - 200 Shot single nozzle
#17 Casper 383 -
1/4 et - PA - 9.94 ~ 1/4 mph - 137 ~ 1/8 et - ??? ~ 1/8 mph - ??? ~ 60ft - 1.43
93 Camaro Z28 ~ TH350 ~ Goebel 4000 stall ~ 12-bolt ~ 3.73
#18 Sseeya
1/4 et - NA 9.942 ~ 1/4 mph - 133.57 ~ 1/8 et - 6.312 ~ 1/8 mph - 109.10 ~ 60ft - 1.359
93 Z/28 - 396 NA - Turbo 350 - Strange 12 bolt w/4.30 gear - 28X10.5 Pro Bracket Radial
#19 GuillaumeC
1/4 et - PA - 9.964 ~ 1/4 mph - 141.23 ~ 1/8 et - 6.439 ~ 1/8 mph - 7.35 ~ 60ft - 1.62
95 DGGM Caprice ~ TH400 ~ TT 355 ~ 4200#
#20 Travismcgill2000
1/4 et - PA - 9.98 ~ 1/4 mph 135 ~ 1/8 et 6.34 ~ 1/8 mph 108 ~ 60ft 1.40
94 trans am~ 355ci ~ 4l60~ 3400lb~ Nitrous Outlet plate 200 shot
#21 roadtrip120
1/4 et - NA - 10.075 ~ 1/4mph 135.6 ~ 1/8 et - 6.47 ~ 1/8 mph 108 ~ 60ft - 1.48
94 Camaro Z28 ~ 385 ,Dart CNC LT1 pro 1, T56 Faceplated, Solid Roller, Single Plane, Jessel Belt Drive, XFI
#22 Jayz28
1/4 et - PA - 10.13 ~ 1/4 mph - 135.267 ~ 1/8 et- 6.54 ~ 1/8 mph - 108.495 ~ 60ft - 1.59
94 Camaro Z28 ~ 4L60E ~ 383ci HCI ~ 10 Bolt ~ 3.73
#23 Jolster-
1/4 ET- NA- 10.15 ~ 1/4mph- 133.65 ~ 1/8 ET- 6.47 ~ 1/8mph- 106.78 ~ 60ft- 1.427
94 Z28 ~ TH350 - 5200 stall ~ S60 ~ 3.73
#24 96LT1355Z28-
1/4 et - NA 10.16 ~ 1/4mph 136 ~ 1/8 et - 6.53 ~ 1/8 mph 106.60 ~ 60ft - 1.50
96 Z28 ~ SR 385 ~ Faceplated M6 ~ MWC 9" ~ 4.30's ~ 3200lbs w/driver
#25 green93ta-
1/4 ET - NA - 10.18 ~ 1/4 mph - 129.57 ~ 1/8 et - 6.42 ~ 1/8 mph - 105.36 ~ 60ft - 1.31
93 Trans Am ~ th350 ~ boss hog 3200 ~ 9in ford ~ 3.89
#26 ShownoMercy
1/4et - PA - 10.20 ~ 1/4mph 139.89 ~ 1/8 et XXX~ 1/8 mph XXXX~ 60ft - 1.8
SNM - 1995 Z28 - PT76gts - 383ci - 24x - 4L80e - S60
#27 Transammann 25 -
1/4 et - PA - 10.20 ~ 1/4mph - 138 ~ 1/8 et - ??? ~ 1/8 mph - ??? ~ 60ft - 1.88
96 Trans Am ~ T56 ~ Spec stage 3+ ~ welded tubes and braced 10 bolt 4.56 motive gears.
#28 Quik95lt1
1/4 et - NA -10.26 ~ 1/4 mph - 131.56 ~ 1/8 et - 6.51 ~ 1/8 mph - 104.4 ~ 60ft - 1.41
95 Z28 3470lbs ~ 4L60E 5k Vigilante ~ 385ci LT1 Ai HCI ~ Strange S60 ~ 4.56 Locker
#29 Ryan Stout
1/4 et - PA - 10.370 ~ 1/4 mph - 147.46 ~ 1/8 et - 7.079~ 1/8 mph - 120.05 ~ 60ft -1.988
89 Mustang ~ Glide ~ 383 ~ GT88 ~ 8.8 ~ 3.08
#30 Agenthol302
1/4 et - PA 10.38 ~ 1/4 mph - 127 ~ 1/8 et - 6.55 ~ 1/8 mph - 103 ~ 60ft - 1.38
94 Z28 ~ 396 ~ TH400 W/4500 ~ 9in W/3.70 ~ 100 N2O ~ 9x29 Tire
#31 Pauly Walnuts
1/4 et - FL- 10.42 ~ 1/4 mph - 128.7 ~ 1/8 et - XX.XX ~ 1/8 mph - XX.XX ~ 60ft - 1.42
396 LT2.5 (Lt1 block, Lt4 heads and intake) , 125 shot, Vig 3200, 3.73's, 3600lbs.
#32 1FASTSS
1/4 et - PA - 10.47 ~ 1/4 mph - 129.12 ~ 1/8 et - ??? ~ 1/8 mph - ??? ~ 60ft - 1.48
96 Z28/SS ~ 4L60E - 3800 Yank ~ S60 ~ 3.73
#33 DawDaw
1/4 et - NA - 10.58 ~ 1/4mph 125.7 ~ 1/8 et - 0.000 ~ 1/8 mph 000.00 ~ 60ft - 1.41
95 Camaro Z28 ~ TH400 ~ H/C 383 ~ E85 ~ 3.89's ~ Mickey 275 Pro
#34 n20camaro
1/4 et - PA - xx.xx 1/4 mph xxx.xx 1/8 et 6.76 1/8 mph 101.9 60' 1.48
95 Z – 383~H/C/I~th400~9”~drag radials~100 shot
#35 Mystery Bird-
1/4 et -NA 10.78 ~ 1/4 mph 124 ~ 1/8 et 6.83 ~ 1/8 mph 99.17 ~ 60ft 1.4695 Firebird ~ 381 ~ 4L80E ~ 3.90’s~ Stock PCM and Opti
#36 Badhawk-
1/4 et - NA - 10.92 ~ 1/4 mph - 121.44 ~ 1/8 et -6.903 1/8 mph - 98.30 ~ 60ft - 1.46
94 Firehawk ~ 4L60E - 4000 Circle D ~ Moser 12-bolt ~ 4.10
#37 Formula 383 (need update)
1/4 et - PA - 10.93 ~ 1/4 mph - 129.9 ~ 1/8 et - 7.15 ~ 1/8 mph -100.99 ~ 60ft - 1.78
97 Formula ~ M6 - S60 ~ 4.10
#38 Engineer-
1/4 et - NA - 10.97 ~ 1/4 mph - 126.9 ~ 1/8 et - 6.98 ~ 1/8 mph 97.47 ~ 60ft - 1.49
97 Camaro Z28
#39 "NO SHOW"-
1/4 et - 10.978 ~ 1/4 mph - 116.81 ~ 1/8 et - 7.007 ~ 1/8 mph - 97.69 ~ 60ft - 1.44
Car (92 RS Camaro) ~ Transmission T56 ~ Centerforce ~ 9" ~ 4.30's
#40 OVA1-
1/4 et - PA - XX.XX ~ 1/4 mph - XXX.XX ~ 1/8 et - 7.28 ~ 1/8 mph - 95.7 ~ 60ft - 1.68
96 Z28 ~ Performabuilt Lvl-2 4L60E ~ Yank SS3600 ~ 10 Bolt-Eaton Locker ~ 4.10s
#41 Blowndfiz-
1/4 et - PA - 11.30 ~ 1/4 mph - 125.80 ~ 1/8 et - 7.35 ~ 1/8 mph - 97.15 ~ 60ft - 1.74
94 Z28 ~ T56 ~ McLeod Street Twin ~ Moser 12 Bolt ~ 3.73
#42 Zohan
1/4 et - PA - 11.42 ~ 1/4 mph - 123.09 ~ 1/8 et - 7.35 ~ 1/8 mph - 95.44 ~ 60ft - 1.62
#43 Chopstix-
1/4 et - PA/NA 11.510 ~ 1/4 mph - 116.68 ~ 1/8 et - 7.323 ~ 1/8 mph - 94.23 ~ 60ft - 1.585
95 Formula ~ stock 350 ~ Th400 ~ 12 Bolt ~ 4.30 ~ 2925#, +1483' DA ~ Bolt on gen2 LTx
#44 SexyTransAm
1/4 et - PA - 11.60 ~ 1/4 mph - 116.8 ~ 1/8 et - 7.40 ~ 1/8 mph - 92.9 ~ 60ft - 1.60
95 Trans Am ~ Performabuilt 4L60E~ 3200 RevMax ~ stock 10 ~ 3.42
#45 AChotrod
1/4 et - NA - 11.682 ~ 1/4 mph - 119.12 ~ 1/8 et - 7.5 ~ 1/8 mph -94.53 ~ 60ft - 1.68
96 Formula WS6 ~ M6 - McLeod Street Twin ~ S60 ~ 4.10
#46 Biggriff-
1/4 et -PA~ 11.84 ~ 1/4 mph - 112.57 ~ 1/8 et - 7.53 ~ 1/8 mph - 91.65 ~ 60ft - 1.69
93 Z28~"Pretty Much Stock" ~ A4 ~ Vig 3600 ~ 10-Bolt ~ 4:10's
#47 Zooguy –
1/4 et - PA 11.902 ~ 1/4mph 113.73 ~ 1/8 et 7.627 ~ 1/8 mph 92.19 ~ 60ft 1.6861994 Formula~Stock LT1~ 4L60e~2.73’s~150 shot
#48 1SLOLT1-
1/4 et - NA - 12.08 ~ 1/4 mph - 111.81 ~ 1/8 et - 7.667 ~ 1/8 mph - 88.75 ~ 60ft - 1.631
95 Z28 ~ A4 ~ SS4000 ~ 10 bolt ~ 3.42
#49 BigT94Z-
1/4 et - NA - 12.25 ~ 1/4 mph - 110.22 ~ 1/8 et - ??? ~ 1/8 mph - ??? ~ 60ft - ???
96 Formula ~ Stock 10-bolt ~ 3.23?
#50 Badazz96z28-
1/4 et - NA -12.386 ~ 1/4 mph - 112.97 ~ 1/8 et - 8.002 ~ 1/8 mph - 89.29 ~ 60ft - 1.899
96 Camaro Z28 ~ T56 ~ 10-Bolt ~ 3.73's
#51 84MONTESS-
1/4 et - NA -12.88 ~ 1/4 mph - 104.92 ~ 1/8 et - 8.25 ~ 1/8 mph - 85.13 ~ 60ft - 1.886
93 Formula ~ Stock 139K mile lt1 w/ lLT's ~3.73's ~ Drag Radials.
#52 BlackWidowSS-
1/4 et - NA -12.99 ~ 1/4 mph - 110.60 ~ 1/8 et - 8.51 ~ 1/8 mph - 86.67 ~ 60ft - 2.11
97 SS Camaro ~ T56 ~ Competition 2+ Clutch ~ 10-Bolt ~ 3.42's ~ 5,427 D/A
#53 Z28Rob18-
1/4 et - NA - 13.1X ~ 1/4 mph - 106.XX ~ 1/8 et - ??? ~ 1/8 mph - ??? ~ 60ft - 2.26
95 Z28 ~ M6 - Stock clutch ~ Stock 10-bolt ~ 3.42
#54 JCZNova
1/4 et - NA - 13.28 ~ 1/4 mph - 99.05 ~ 1/8 et - 8.34 ~ 1/8 mph - 80.14 ~ 60ft - 1.76
'70 Chevy Nova ~ 4L60E - Yank 4000 ~ Ford 8.8 ~ 3.73
#55 Firefighter Z-
1/4 et - NA 13.33 ~ 1/4 mph - 101 ~ 1/8 et - 8.45 ~ 1/8 mph - 83.43 ~ 60ft - 1.78
Car 1994 Camaro Z28 ~ CC503 cam 355 NA ~ A4 ~ 3:23 ~ 10 bolt ~ 3600 stall ~ 12x19 Street Tire @ 25psi ~ Own tune
#56 Sahara54
1/4 et - NA - 13.59 ~ 1/4 mph - 97.93 ~ 1/8 et - 8.55 ~ 1/8mph - 77.76 ~ 60ft - 1.82
94 Formula ~ CC503 355 ~ 4L60 - 3200 Vigilante ~ 10 bolt ~ 2.73 gears
#57 DanDalessandro
1/4 et - NA - 14.86 ~ 1/4 mph - 95.80 ~ 1/8 et - 9.686 ~ 1/8 mph - 75.41 ~ 60 ft - 2.37
97 Z28 ~ 5.7 ~ T56 ~ 10 bolt ~ 3.42 gears
