Procharged Ellwein 383 thru an auto, whp poll
Let's get your guesses in here guys, I'll put a small poll at the top. Specs are as follows:
Ellwein 383
-9.0ish compression
-Oliver splayed 4 bolt, cola crank, Callie's 6.0 rod, Wiseco dished Pistons
-LE2 heads, LE custom blower grind (229/239 .565/.587 112lsa)
-scorpion 1.6 rr
-.040 cometics
-ported intake
-Siemens 60lb
-TPIS 58mm dual blade
-Lonnies double pumper 255's with 4psi Hobbs switch
-Procharger p600b pullied to just under max blower speed (should be around 9-10)
-CX Racing 3" intercooler, the big one, Procharger bullet open blow off valve
-LPP Longtubes, ory, lm1
-Pro Torque 9.5" billet faced 3200 stall
-CPT Pro Race 4l60e with billet output shaft
-aluminum driveshaft and 3.42 10 bolt for now (eeeeek)
motor dyno'd on engine dyno na at 490/490 hp/tq with a carb and dual plane
will we see 500whp or more?
car goes down on Monday.
