What do I need for injectors? '93 vette
I'm really confused about what fuel injectors to get for my car. It has an LT4 hotcam, mostly stock otherwise.Email tune. I just want to change the injectors. It has the stock 17087325's which flow anywhere from 18 to 25 lbs. Depends on who you ask. I have a set of 17121068's that flow either 19.45 or 22.76 lbs. All at 43.5 psi. That info came from this site http://users.erols.com/srweiss/tableifc.htm And I have some blue top fords, and some orange bosch's off a ford. If they're rated at 32 psi, the 19's should flow 22.xx lbs at 43.5. Then theres the stock injector flow rate programmed at 23.80. Basically I want to replace the old original injectors. How do I know what size to get and what do I need to change in the tune? Thanks in advance for any info.
The stock injectors are fine for your setup. You won't need to upgrade injectors until you have modded your car to the point that it's starving for fuel.
Even with a tune, there won't be a horsepower increase.
With that said, a popular injector size for n/a engines is 36lbs.
