Anyone interested in not having to remove the water pump in order to change the opti?
This concept spaces the lt1 water pump off the block just enough to allow the optispark to be removed without having to actually remove the water pump. This obviously saves a LOT of hassle AND in spacing it away from the opti, allows a little more airspace around the unit, allowing it to potentially run cooler, and keeps the weep hole from weeping all over the opti in the event of a failure. Possibly the biggest advantage of this is the confidence to run your run of the mill parts store opti with a lifetime warranty and never have to pay for another again, without the hassle of draining the coolant system if/when it goes bad. Because of the nature of this mod, electric water pump users are probably not going to be able to run the spacers without some extensive trimming of the radiator fan shroud (I highly doubt a mezierre will fit, a CSR or jets unit MIGHT).
Basically this kit would include two CNC aluminum 1.25" spacers, extended bolts, two sets of water pump gaskets, and either a new or extended water pump drive coupling. Still working on gathering materials for production pricing, (and possibly a vendor to supply internally splined couplings so i don't have to weld an extension to the OEM coupling.... aka more money) so that is still an unknown at the moment but I'm looking at around $150 shipped (this is an ESTIMATE, not a final price!)
This being said, give me your thoughts and opinions on the concept and if you think this is a product you would be interested in.
Here are a few quick (and dirty) videos showing the installed water pump and the removal and installation of the opti to show that it works, and a pic of these beautiful spacers....
https://www.youtube.com/watch?v=wx3l4GmvTyc
https://www.youtube.com/watch?v=7KIB4LDxFx8
http://img.tapatalk.com/d/14/04/10/ebybu5am.jpg
http://img.tapatalk.com/d/14/04/10/ge8u2ura.jpg
