I have a 383, forged eagle crank, studded mains, srp pistons 16cc dish, eagle h beam rods, block is half filled it is a 93 block its been decked the engine it self looks brand new inside besides the bearings. lets just say ive had it for over a year and im trying to figure out where to go from here with it. Problem is it has a 2pc rear main crank. I have a t56 trans so i would need a aftermarket flywheel set up for that (bolt pattern is diff). Now what would i do about balance on the front an rear of the crank? This motor was built many years ago. it is a lt1 motor and has the 2pc rear main adapter on the back of the block it used to have a 700r4 behind it an a sfi approved flex plate. It had a stock lt1 crank and hub i believe but i do not have it. Is there any way to tell a internal balance or external balance crank, or if i will need a special balance flywheel and balancer? i ran the part numbers on the crank and cant come up with any info. so please help. heres a few pics so u can get a idea oo an the date on camera is correct back when i first got the motor for christmas
http://i619.photobucket.com/albums/t...t1/383side.jpg
http://i619.photobucket.com/albums/t...1/383side2.jpg
http://i619.photobucket.com/albums/t...t1/383rear.jpg
http://i619.photobucket.com/albums/t...1/383front.jpg
http://i619.photobucket.com/albums/t.../383bottom.jpg
http://i619.photobucket.com/albums/t...383bottom2.jpg
