remove wheel weights on the drag wheels. once you do a burnout they are gonna be out of balance anyway with the weights. i have no weights on any of mine, no vibration, had vibration with weights
Why the desire to have KS work with holley? Honestly curious. Also are you talking injector end angle tuning?
Less plug reading and guessing. No idea how good the knock circuit is, but something seems better than nothing.
And yea, the end angle. I believe it is fixed in the base tune. I've been reluctant to change it because I know it's going to throw all of my low rpm fueling out the window.
As a data point, I swapped in 220# injectors, and updated the ECM for the new injector data. Checked learning trims, and their close to if not zero area.
Then I switched on the IEA (mainly cause I like to tinker) and have driven it for awhile now. Learning trims still show next to no areas that indicate change is needed.
Data wise, didn't seem to do much, BUT in my head, seems to have cleaned up idle and the off idle slow hits quite well. So who knows.
Just getting around to tinkering with this thing again. A made a couple tune changes and it seems to be driving less like an old farm truck.
1. I got around to setting up the IEA table in the advanced ICF. I used the v2.6 excel that is floating around and have been experimenting with a few different inputs. Right now it is about -160° at idle and it generally hangs out between -155° and -175° during cruising. Throttle response is 1000% better than the fixed -90° from the base cals, idk who came up with that figure and the built in injector phasing calculator is trash.
2. I upped the min injector pulse width to 1.65ms. These Deka 80s seem to act all wonky starting at <1.55 and were causing lean pops on decel. Unfortunately, a side effect of this is that the pulse width hits the floor too fast during coasting and my fuel goes to 11:1. BUT...
3. I got the DFCO working properly which can be a band-aid for hitting the pw floor.
@shownomercy What were you running for IEA on the 80's? I looked around in the old tune you sent me, saw it was fixed at 0° and didn't see anything in the advanced ICF tables.
I never had IEA setup on the 80s afaik, I only started messing with it once I tossed the 220s in.
