Pulled most of the stuff out of the engine bay. I need to put a new bearing in this Torqhead dummy opti before I can put that on. It feels a little grindy, but that's probably because it fell off of my desk. Also need to reseal the blower because it leaks a little oil.
Attachment 40178
Also pulled the rear out in order to swap the gas tank/lines. I also want to fix this shitty Moser TA mount once and for all as this housing has always fit like dogshit. Notice something off about the TA mount tubes?
Attachment 40179
~94 degrees. I'm guessing this is supposed to be 90? Probably explains why I needed to shim the TA mount with washers to get the TA anywhere near the right spot. See ancient photobucket pic from 2014 to see what I mean.
Attachment 40180
https://hosting.photobucket.com/albu...ps68c186e9.jpg
I'm going to angle mill the TA mount so it sits flat and no washers are necessary. I know Moser will be of no help like they always are.
