Think I may have toasted the clock spring but, its in for now. Need to pull it off to loctite and torque when its ready to move again.
https://i.imgur.com/BpI0U0rl.jpg
https://i.imgur.com/IH1FZHGl.jpg
Just wait till I stance it!
Not much to update, PAX header is roughed up, just need to tack it up and then start the last piece connecting PAX header to turbo.
Decided to minimize 3in used in downpipe... enter 4in 90* bend...
https://i.imgur.com/yeiPQBhl.jpg
I really hope this combo still makes steam cause all the SCH10 SS is adding a crap ton of weight :lol:
Started to remove more of the car cause winter boredom.
https://i.imgur.com/0fS91Orl.jpg
https://i.imgur.com/oYl3sQ2l.jpg
https://i.imgur.com/VoIjGKTl.jpg
https://i.imgur.com/zQDpTMQl.jpg
Hopefully no more hissing,crackling, and lousy sounding noise thru speakers
So it works, sorta. Had wired it via stock power/key on, and had no power at plug. Fuses had power and at that point said F it. Will be wiring that to the Holley board as well. Hotwired it to verify speakers and head unit worked.
https://i.imgur.com/sDFCuKrl.jpg
So, like everything else, a plan was made and a plan was completely ignored. :rofl:
Its now part of teh car officially.
https://i.imgur.com/uSgHGzRl.jpg
Will hook up power to board over the weekend and verify engine cranks, power at Holley etc. Then yank wires, shrink connection seals and what not.
#progress
Pax side all done with tack up and fitting
https://i.imgur.com/aVc3aACl.jpg
https://i.imgur.com/Hgey212l.jpg
We getting close now
Hotside almost all tacked up, next up is wastegate, turbo mount, and some downpipe support
4in downpipe and assorted hotside pics.
https://i.imgur.com/k4E2l7ul.jpg
https://i.imgur.com/qMWLzDnl.jpg
https://i.imgur.com/zYK0kqxl.jpg
https://i.imgur.com/EgpVxvil.jpg
https://i.imgur.com/hAgAtP8l.jpg
https://i.imgur.com/lv8sIN0l.jpg
https://i.imgur.com/3C6BW3Dl.jpg
https://i.imgur.com/nI4sppVl.jpg
Long day of cutting, grinding and ruining harbor freight hole saws...
https://i.imgur.com/fBX1g0Jl.jpg
Last fab work hurdle done, gotta order up a quality hole saw and some carbide bits to clean up holes.. then off to the final tig weld stage.
Light at end of tunnel gents, which means I need to finish wiring up car
