I like all your count downs.
Daniel ran the cobra at the track today. Ran a 9.6 with a valve issue. Quit pulling at 5k and started popping through the carb. Running a compression test tomorrow. Atleast its up and running :thumbup:
lol, you're probably right ......Quote:
Originally Posted by popo8:306726
Just give it an hour or so...think it over...then tell me so i can change it lol
1/8th its just a 357. I'm sure he didn't push it too hard breaking up. He had a 750 Holley vacuum secondary and ran the 9.6. Switched to a 750 demon double pumper and the valve issue really showed its head. But the good news is its running and the engine is running fine just a little issue to work out.
Make sure the rocker arms are adjusted good.
It was a popped headgasket on the drivers side (side fire was on). He replaced the gaskets. This issue was a previous one in the formula but it wasn't as bad. It would stop pulling at 5k but still had enough power to walk my friends bolt on ls1 ss. Sitting apparently made it worse.
I will pass the info on Chile.
