Maintenance on my '94 z28 pic heavy
@Injuneer I I should have labeled it - the grid on the left was L/R average BLM+INT average together. The right side is the L/R avg of just BLMs. This is the data of all my logs.
I did another datalog last night of the car cold (32F) start to hot with maybe 6 hot cycle at idle. The BLMs were closer then dropped to 111L 118R with INTs steady at 125 both sides. This was after idling for 20-30min. It didn't look like it was going to change much from there.
The popping and shaking really became noticeable at 800 seconds after starting. This was before closed loop or BLM mode was activated. It's always worse the hotter the car is.
I can't find many reasons why a car shows a rich/low BLM besides leaking injectors. I'm not sure if my car is really rich at idle or the pcm just thinks it is.
@Injuneer You were right on the vac leak Fred, it was my K&N filter making the noise - It had almost fallen off the tube. I hit the bugs out of it but didn't re-oil. The 800 seconds bad idle was in my mind. I forgot that I was watching my O2mv drop for a few minutes before I started the car :embarassed:. The heaters must run with the key in acc. You can view everything in EEhack like you can in scan9495. I took that picture to compare it after I do my exhaust/02 and opti.
Here is a shot of the pump my idle is getting worse. http://uploads.tapatalk-cdn.com/2016...830b90dfee.jpg
My torque arm bushing is cut in half. I've got a new one of those too.
Edit: I may buy this http://www.opti-shield.com/opti-shie...tallation.html for my new water pump:jest:
