Would really appreciate that photo of where you had to grind the stock K-member ........ when you get the chance. Thanks!
LOL Yes me too
You guys are killing me....lol
The lip on the driver side that runs parallel to frame rail. Is where you may need to grind. Haven't pulled the K yet. Giving my body a break for a few days.
Poor pic sorry
Attachment 19520
As for mounts. Use a poly like energy suspension ect. For test i used my old stock k with rubber. My tubular has poly.
Shame you guy's won't make a big tube version, I asked like a year ago to check :(. I know the market for that is real small, but there is literally no off the shelf big primary header - we have to get custom ones from Kooks or Lemons which cost an arm and a leg.
I agree completely on the mounts and fitment. It really makes a HUGE difference. When I did my engine swap, the motor mounts and trans mount were 100% brand new poly mounts. When I installed the LPPs while the kframe and engine were out of the car (the engine was mounted to the kframe), I had a ton of clearance. When I installed the assembly into the car for the engine swap, I still had a ton of clearance. I drove it around town put about 80 miles on it and I spun two bearings, had to tear it all out and rebuild the engine. When I mounted the rebuilt engine to the kframe and then mounted the LPPs back on I had a lot less clearance than before and by the time it was buttoned up into the car I had no clearance and had to do some adjustments. I can't imagine that the poly mounts would have sagged over an inch that quickly, so my only other thought was that there's a lot more "wiggle room" for adjusting the headers when you install them to the engine than might be apparent.
Waiting for input from the other two that bought the headers:(
Lets go guys. Get them in so LPP can start making these for all the peeps in here:)
