http://www.summitracing.com/search/?...%20bolts&dds=1
http://forums.corvetteforum.com/c4-t...-any-help.html
I think you mean head bolts, not studs.
As far as the mounting bracket, I'm not sure. I have the SDCE kit, and my setup came used with it.
nope, i meant head Studs.....i think its APR 234-4601 or 234-4401
Why do you want to do head studs? Guys making much more power than you will are still using bolts.
its just me over building.....i have a bad habit of doing that
and studs hold a better more even torque
^ True, you're right, they are a better fastener torque-wise.
Any application for SBC will work.
I way over-built mine...and used bolts. But whatev, to each his own.
all i know is the "small" items are going to kick my wallets ass! so far, pushing almost 2k for oilpan, pump, pickup, engine bolts, headers. still need lifters, push rods, fuel pumps, injectors, crank hub, dampener, pulleys..... it just seams the parts list gos on for ever! lol
^ Welcome to the world of boosted builds, or really any build for that matter. When you're in the "dream" phase, you're only thinking about the big stuff, the major components. That's where people screw up on budgeting, and a lot of people give up on builds and part it all out for a fraction of what they paid because they can't finish due to financial issues.
It's all the smaller components that you don't really think about that really kill your budget in a big hurry.
<---- I didn't title myself as I did because my build was cheap and under budget.
ya, I basically threw the "budget" out the window, I would rather take longer and build what i want then go cheaper and end up cutting corners....
well not doing enough research before buying has kinda bit me in the ass! looks like i will be with the P1 w/8rib set up for a wile. just going to get a smaller pulley (4" or 3.7"). i just don't have the extra to shell out for the SC upgrade and the 12rib pulleys and new main bracket.
