Got the car out on the highway this evening. Seems to shift good from what I could feel at low speeds. Hard to tell what's going on at the higher rpms. Tried out launching it on a concrete bridge and the tires hooked pretty nicely. I think if I found a way to mellow out the blast of boost right out of the hole it would hook a lot better. Tried again on some asphalt and it just spun. Using scan 9495 it's commanding all 4 gears properly. Only thing I'm not seeing it the tcc but because it's an 80e his program may not pick it up. I'll have to look into that a bit more.
Awesome... nice firm shifts?
What do u mean hard tomtell at higher rpms? Like something is not right???
Like massive wheel spin lol
I was also trying to get a good datalog with my new crank pulley to see how much psi i picked up but when I got home I found a rubber cap blocking off one of the blower taps split in half. I have a feeling this is going to be a pita to tune
Just because the Street Outlaw guys dead hook on the street doesn't mean you can :laugh:
I think you will hook it just fine on a well prepped track.
Hahaha yea those "streets" are prepped better than most tracks I've seen.
Are u still runnin a ms3?
No I'm running accel dfi. HOWEVER, I believe I will be switching to another platform if this one doesn't work out with piggybacking the transmission. Shouldn't be a hard sell. It's a great system if you're only controlling an engine or even an engine with just torque converter lockup. I just don't see many reports of guys running computer controlled trans with the dfi. The ms3 now has a "megashift" board that will fully control a trans. We'll see what happens
Ok.. I remember puttin u in touch with chris a long time ago about the ms cause he was runnin one in his 93. Btw did u know the owner/designer of the ms systems lives 20 min from my work...
No but that may come in handy in the future. The guys that have designed the ms system are friggin geniuses
