i found the sensor, thats about the extent of it. broke the rest of the underhood side of the box out. some trimming and when the block off plate shows up will go back together. also have to:
Retorque intake bolts
check lash hot
install summit ewp
install radiator/fans
be the zip tie master
thank you fred, that helps, that actuator can stay removed and plugged then.
I got a 200 dollar wrecked 02 blazer from a guy at work, under 80k miles, some body rust at rockers. been playing with that a little since its warm and its outside. hoping to fix/flip for some cash towards the bird
Attachment 40384
