I will try to get a pic tomorrow of where i had to grind. When i pull it to put my PA k-member back in.
I put the the driver in from the top. I had to remove steering linkage and unbolt driver motor mount and lift engine about 1 inch(i also had to pull my canton valve cover but stock one you won't)
Passenger went in from bottom. I had to remove starter. And dip stick tube. Don't know if you have to remove tube. I just did it to be safe.
