http://m.oreillyauto.com/mt/www.orei...0422&ppt=C0141
Thoughts? Since now I'm throwing a cam in, would it be a good idea? 111k miles team!
Oil pump/housing?
Teeeaaaammmm
Oil pump/housing?
Teeeaaaammmm
Well, I'm slowly collecting parts and making moves. Picking up a set of oem 9697 SS wheels, emailed Lloyd about cam and shit.
Already have a replacement timing set, gaskets(minus head). Need to put together a cleaner list.. I have a fuck ton of parts in my bedroom right now.
If you are going EWP then get a nice single roller, otherwise, if stocker is not to loose, leave it be.
I would get the high pressure spring for oil pump along with an ARP driveshaft for the pump. Leave OEM factory pump in though.
http://m.summitracing.com/parts/NAL-12371043
This is the ZZ4 single which has the same chain and crank sprocket as the LT4 ED set for $200 less. Only difference between the two is the water pump provision on the LT4 cam sprocket. If you have a pin drive opti and EWP then run the ZZ4.
If you are doing a timing chain, pro gear gets my vote.
http://shanonsengineering.com/produc...-set-1985-2002
Lloyd may be able to source em for you. I have run two of em now with no issue.
I got the Cloyes stock replacement from work.
http://uploads.tapatalk-cdn.com/2016...d2c0f719f3.jpg
4th is in the back seat. Hot diggity 96-97 SS wheelz!
Also. Let's talk valve covers. With the pro mags, is extra height needed? Because I can get proform valve covers at work and they are a 1/4 inch taller. Or do I just go with cantons?
Fuck cantons.
LT4 composite covers.
/thread
Don't you have cantons.?
http://uploads.tapatalk-cdn.com/2016...61194a67ae.jpg
I thought these were nice..
Negative ghost rider.
