Lol unmentionable. No I think my best was 13.4@108 2.6 60'. I'm a lot to blame for it. I didn't let any air out of the tires after the true street cruise. The tire shop set them at 35#. I figured it was the drag SLICK guys that dabble in the low pressure areas until I talked to brad that was running 12# in radials. Later learned that the tires on my dads car were mt s/r sportsmans and not et streets like I had originally thought. Took some air out and tried launching off idle, longer burnout, etc. Couldn't get traction until, I don't know, somewhere after the lights. Bottom line, I built it from the front-back, which I know was wrong, but I still wanted to bring it to see how it would do. I think the reason Larry said it had potential is because after it hooked up, it seemed to get up pretty good.
Interesting note, I tried running a colder plug, autolite 105 gapped at .035 and the car did not like it at all. Wouldn't idle, backfired at high rpm off throttle. I put the autolite 106 gapped at .045 back in it and it was healed. I'm going to have to investigate that some more...
