Focus on the impala and bring the old man with u.
well, fingers crossed that the lt1 gods may bless this build....there still may be a chance, albeit a slim one. but a chance.....
Attachment 32117
Attachment 32118
karl just let me know he is picking up the crank tomorrow. there is a small chance he can get it together, but if he runs into a problem, its not gonna happen. either way, we greatly appreciate Karl's dedication to trying to make the deadline, with honestly only having a short period of time to work on it with his very busy schedule on his end. He is a very meticulous builder, leaving nothing to chance, and we have the utmost respect for him. he constantly updates you on your build, and is very honest. hard to find that now adays in people in general. if you want the best, have Ellwein Engines build you a motor.
That is refreshing news with so much dishonestly around... keep us posted.
@popo8 this was a refreshing pic to receive just now http://tapatalk.imageshack.com/v2/15...6a918754b6.jpg
Nope, timing chain issues. Not gonna make it. Shit
I saw u complaining about something on fb "spline drive" something... but not sure what the issue was.
Timing chain was too worn and gears were too worn. For anyone that looks for a spline drive timing set it's a nightmare, and expensive, so you're better off upgrading to the 95-97 opti. Well the cam pin has to be shortened for the early setup, now he couldn't get it out
Can it just be shortened if removal is not an option?
Ohhhh. Some heat at it wont get it loose?
If you (or someone you know) can weld, just tack a 1/4" slide hammer rod to the pin and slide hammer it out.
Yep, that's it. No biggie, it's a little depressing, but we will move forward. Now there's not a rush on the car, and it's gonna be done 100% fine tooth comb, also, engine will be broken in on the dyno, and possibly gonna go with a smaller pulley from blower works right out of the garage lol
http://images.tapatalk-cdn.com/15/05...a40e805463.jpg
All ready for the engine dyno. Pro mod taking up engine dyno, once it's done karl will bring it over there and get this bad boy making or breaking something. Still waiting on lonnies double pumper setup. Now we wait.
What are you expecting power wise?
Expecting it to not blow up. Lol. Long rod 383 with le2 heads and a blower cam, like 26 hp less than urs maybe?
Cam specs 226/239 .565/.587 112 LSA @blackbirdws6
Should be pretty close to mine for sure.
What are you running for a head unit? Pump gas and meth?
Looking good
Should be good for a 10 second slip?
Run it!
Eventually he will, not my car, or I'd be beating the shit out of it when it's together
Street cars can't run 10s?
Expecting A little less that @blackbirdws6 made on the engine dyno NA with the engine on the engine dyno NA.
500 whp on boost thru an auto in the car.
Eh it's an auto car, 10 bolt should be fine. I actually never have broken one, wore out two posi units though, granted my hp level isn't monsterous but isn't exactly far off from your goal. Only went with a 9" because didn't feel like putting more money into repairing my 10 bolt. Both posi units were used, not new btw.
I've broke a 10 bolt with a 305 84 camaro.....
I peg legged one of my 10 bolts, but ran 11s at high 130s on it. :lol:
500hp NA means 1000hp boost capable!
Pat Burton was running 9s on his 10bolt iirc.
Who knows. .. 10 bolts are weird. I know a turbo lt1 out of chitown went 9 . teens at 150 Mph on a bone stock 10 bolt. His username was robsquickz28.
I think you'll be ok but then again I've seen them break at stock power levels so it's purely a gamble.
