Maintenance on my '94 z28 pic heavy
Quote:
Originally Posted by
Injuneer
I'm not sure what function those 2 small holes just above and to the side of the pintle serve. There are no matching holes in the gasket or in the intake manifold.
The factory manual indicates the valve should hold vacuum for at least 20 seconds.
I couldn't figure that out either. I tried to clean them out, but they are just holes.
Most of what I learned was from here.
http://www.tomco-inc.com/Tech_Tips/ttt27.pdf
The 2 little pintle holes on the tipa keep the pintle closed incase manifold vacuum keeps the valve open. It took me a while to understand it. There's a lot going on for such a small part.
Mine held open for as long as I held my thumb. I couldn't blow threw at all once it was clean. Glad I don't have to blow the pintle anymore haha.
I've got an update and some more questions. I finally got the o2 sensor changed. Haven't ran a log yet. It's been rainy/wet roads so I can't hear the car very well, but it sounds like the idle is better.
My question is about the pulley driven stuff. I haven't been able to find a lot of info on this. One or more of my pullies is really noisy.
What is the best way to test a pully? Does it need to be completely tight? No movement front/back or radially ?
When I removed the alternator for plug wires it made some noise when I spun it and squeaked a little. I can't spin it up at car speed by hand though.
Also my AC system belched oil over the belt and I'm sure everything connected. Don't know how bad this is for pully life.
So my questions are:
1. How much and what is normal pully movement.
2. Is oil bad on pulleys.
3. My AC compressor seal is bad/leaks. Would this cause a noise also?
The couple of times I took the serp belt off it looked ok I may get a new one though.
I'm definitely going to do headers soon. I tightened then up and it seems to have made it worse. I'm going to do this over Christmas probably. Not sure if long tube is what I want I have been looking at mid length headers. I'm pretty broke right now so any system that I can easily hook up to stock exhaust would be a plus until I can change that out. I'm more about making the car easier to work on then getting maximum HP.
1 Attachment(s)
Heres a datalog shot using EEhack. This was during a trip to my dads. Around 20 miles highway driving.
Attachment 37239
Im going to work on tuning and datalogs today while I have time.
Here's a shot of the removed AC partshttp://uploads.tapatalk-cdn.com/2016...71e37a37d5.jpg
