You might want to try jumping and see if you are getting any codes.
No codes. Seems like the laptop isn't getting a feed from the PCM. Everything is te same on the dlc connectors. The 95 (old car) has a wire on the top right it's black I think white stripe. All the rest are same. Colors and locations
This one says there's another power for the PCM in the 96. But I shouldn't need that one right? Since I'm using the 95
http://shbox.com/1/harness_connector_faces.htm
C220 pin E. The white connector inside car. Kick panel on the pass side
I'm not getting any power for the PCM stuff. I pulled the red connector for the PCM. Checked a couple grounds with my led. They're working. Just no power on the couple wires that should have power bow
I was thinking same thing. I just have a pwr rubbing up to the splitter 4 now
I'm confused? Since you are using the 95 harness and pcm shouldn't the only issues be at the body harness? Maybe I just miss read something.
