Doesn't that crossover see high temps? Will that hose handle it? Just wondering case that crossover is called a steam pipe.
It dosent get too hot ... keep the motor about 160 or less
I took off work to go out to the LTX shootout regardless of my car being finished ... however now that the event has been postponed I have 5 days no work and a car not finished..... beautiful weather perfect opportunity and tons of motivation I'm going to give this thing put together
Today .... wires
EWP, fan, line lock, nitrous fuel cell
Now I just have to run signal wires to my switch panel ... all in all I think it turned out goodhttps://uploads.tapatalk-cdn.com/201...9bc885868b.jpg
Well motor is done and wired up and done.
https://youtu.be/D6i1nUABF0Y
Well a big step was finished today ... th400 was installed. I put in a 9" FTI 3800-4000 stall. So next step is put in the trans coolers in and run trans lines. Measure for a drive shaft then drive.https://uploads.tapatalk-cdn.com/201...3b8eece5da.jpg
Still need a drive shaft measurement
Got a yoke for the transmission and measured for a drive shaft. Loos like I'll need 43 1/8" center to center on the flanges so I have a driveshaft that will work ... just need to chop about 1 1/4" off it or shorten the yoke uphttps://uploads.tapatalk-cdn.com/201...2067f37d86.jpghttps://uploads.tapatalk-cdn.com/201...587bd8291a.jpghttps://uploads.tapatalk-cdn.com/201...6b2f1d688f.jpg
