Question: What is the smaller hole in front of the bypass valve?
I believe that's the bore for the butterfly valve shaft.
You talking about the one that looks like a grommet? Can you circle it in mspaint or something?
Here ya go!
http://i.imgur.com/nRZv51y.jpg
I can't think of anything it could be. There is a matching hole on the elbow mount as well.
Thank you for all your help!
Oh I was looking at the bypass valves on whipples page. That's a bolt hole for the adapter plate. On the supercharger next to the plate you can see the bypass valve (gold) at the top of the pic. Right below it is a tapped hole.
I'd say its more to ensure sealing around that area
Thats what I meant to say. That bypass valve is going to be tricky, I'll have to shop around for possibly some parts I can scavenge off a carburetor.
As for the bypass valve, the actuator vacuum line isn't anything special, correct? Just a normal engine vacuum line.
Yes just a normal vacuum line
