Shit... what hapnd? I was at work... missed the news.
Strike to an empty airbase where gas was launched from supposedly.
Russian officials were informed of the strike. Supposedly zero casualties.
Definitely can't trust mainstream media with this. Took a lot of digging to find it at the time, now it's becoming more apparent. I am eager to see what CNN says!
Any PA folks familiar with this range?
http://www.blueridgesportsmanclub.com/
just got the call! racecar and trailer come home on staurday
How bout that moab
Sent from my SM-G920V using Tapatalk
It's a 16 million dollar bomb... Think of all the roadmasters I could buy with that
http://www.msn.com/en-us/autos/new-y...wqO?li=BBnb7Kz Try that for some bbbbbACON
Local car show. Here's just a couple https://uploads.tapatalk-cdn.com/201...e16fff9df3.jpghttps://uploads.tapatalk-cdn.com/201...2b1dadc3be.jpghttps://uploads.tapatalk-cdn.com/201...786b84f01b.jpghttps://uploads.tapatalk-cdn.com/201...2b173de97e.jpghttps://uploads.tapatalk-cdn.com/201...46a019f3d5.jpg
T minus four hours
Ever see anything like this. Customer just purchased this boat so he couldnt tell me why.https://uploads.tapatalk-cdn.com/201...c1e68c4af8.jpg
Keeps the carb colder and helps with atomization going into runners. Also on boats they sometimes time to level the carb if the motor is on a angle mount etc. Used to make em out of wood, but I think their all fake stuff material wise.
Can somebody give me some advice on trailering a car? Girlfriend has a 01 Sierra 1500, 5.3, 4x4. Planning on going to good track this year that's on other side of the state and using good tires too. I've pulled jetskis and stuff before, never loaded a car though.
Depends on trailer you use. Either way, go slow, and leave distance. Always anticipate people being fucking retarded assholes.
If its a uhaul, you are stuck putting car front wheels where they make you. Idiot proof and usually to much tongue weight IMO. But it will work fine.
If you have access to a real car trailer, and or a decent weigh scale to use, you can get it setup nicely with ~10% tongue weight.
If you do trailer it with slicks on a 10 bolt, you do realize its like 99% sure you are winching it back on trailer right? :lol:
I won't be using slicks, just radials. But I'm going 3 hours away from home, many miles away and a tow back would cost a lot. Just being careful 😂
It'll probably just be a uhaul trailer unless I can get a nicer one for a nice price.
Uhauls are super easy. That being said, bring a jack cause once you get the car on the trailer you can't open the door to get out without raising the car a tad. IDK what tow connectors are on your 1500 but the Uhauls are a flat four pin, so make sure thats good to go. And then grab a nice hitch, they are an oddball size IIRC. Lastly, make sure you bring long pieces of wood to get the ramps setup right, otherwise you gonna drag.
May is always my bog month off... literally take nearly the wntire month off for chillin... winter to spring transition around the house as well as CRUISIN OCMD... Which if u have NEVER... it is a MUST for any car guy...
Ive been off since Tuesday and dont return to duty till the 26th... but I will be playing detective monday trying to knock out 6 search warrants and serve them all the same day.
No... its not like on tv where they make a call and have a warrant.
Its a long process... followed by requiring approval from the DA to then getting it approved by the DJ... THEN SERVING all the warrants.
Fortunately 4 of them are thru facebook so serving those wont be hard... but the other two are on a Doctors office and a hospital. Gonna be a hellacious Monday....
Rant over.
It's been raining a lot here in Michigan
My back yard had a 2 foot pond in it yesterday. Probably should fill in the hole I dug in back..
You Camaro guys and gals seen this ?
http://www.vfnfiberglass.com/932001camaro.htm
Glastek is betttaaaa
Seems I missed the rest of the site theres more to it just saw that . Both sites have good choices . I need to buy hard parts first.
I guess I'm buying my girlfriend's truck. It's a more than good price for me.
It has the typical gm rust. I'm probably just going to undercoat the shit out of it and replace parts here and there.
https://uploads.tapatalk-cdn.com/201...4b7bfe3f52.jpghttps://uploads.tapatalk-cdn.com/201...3f5f075721.jpghttps://uploads.tapatalk-cdn.com/201...baa9b684e0.jpghttps://uploads.tapatalk-cdn.com/201...de794fb265.jpg
The frames on those are notorious for rotting man. If the body looks like that... id be concerned... unless its all but free, Id pass.
I didn't look too hard at the frame, I haven't fully bought it yet. But I'll definitely take a look tomorrow when I go give it a once over. The back driver side is the worst. The right side isn't that bad. I'll have to go over it again.
Preciate the insight
Have fun with the brake lines bro
brake lines rot the quickest, then the rockers and fuel lines. @Ltconvert truck shows it bad. we had a car on trailer and he hit the brakes to stop from 2mph when backing up and the rear hardlines blew apart
My step-dad's 07 Classic is the same way. Rockers are still good but the gas door spring rusted out and just flaps in the breeze. lol
The rust all looks surface. Hit it with a screwdriver and it didn't go through lol.
From what she's telling me, all brake lines were replaced after one blew apart lol.
What do you guys think? The shocks are definitely blown out because the shit bounces all over the place lol. https://uploads.tapatalk-cdn.com/201...62461050bc.jpghttps://uploads.tapatalk-cdn.com/201...58ee8c254e.jpghttps://uploads.tapatalk-cdn.com/201...b035d70bfe.jpghttps://uploads.tapatalk-cdn.com/201...3269b76ada.jpg
Hit it with a wire wheel and spray it down. I've seen worse on jeeps Ive worked on and still beat the hell outta em.
The only thing I'm doing to it if I do go ahead and buy it is undercoat it and fix the damn brakes.
You can't stop for yellow lights lol. They are so bad.
wanna hear about bad brakes, ask @popo8
