Not yet ... but everything points to the cam
Well I got the old camshaft out and the new Lloyd Elliot spec'd camshaft should be here this week ....
https://uploads.tapatalk-cdn.com/201...bf3f1d90dc.jpg
well got the cam in from @NightTrain66
https://uploads.tapatalk-cdn.com/201...63a24a15bc.jpg
its a big boy and its installed now time to once again button her up and try to start it. and here is a pic of the timing chain installed THE RIGHT WAY for TDC on compression stroke for number 6 piston
https://uploads.tapatalk-cdn.com/201...ee2ad68867.jpg
hopefully this will correct the problem.
I'm not sure how the old cam would not let it carnk but at least you can scratch the cam off of the list now.
As long as you install the new cam correctly and you have compression, you should be good to go.
Just add the correct amount or air, fuel and spark . . . . . . . no reason it shouldn't run then.
Lloyd
Waiting to see if the new cam fixes the issue. When will u fire it, or are u goin back to the engine shop?
OWNER/ADMIN
Watched ur cam instal video... so painfully boring but i watched it all. Lol
OWNER/ADMIN
ill make a better video next time
Please... and just start it... that long period in the beginning just staring at u doing nothing was torture. Lol.
OWNER/ADMIN
any word yet?
Lloyd
Yes my Springs came in yesterday
so I got a little bit of progress this weekend
https://uploads.tapatalk-cdn.com/201...3295adfe42.jpg
I got the oil pan and timing cover gasket surfaces cleaned up fresh gaskets got the water pump back on.
So with the new camshaft I decided to step up 2 some better Springs.
Out with old
https://uploads.tapatalk-cdn.com/201...cbb2ef9803.jpg
In with the new
https://uploads.tapatalk-cdn.com/201...e2ed77a054.jpg
And this was the torture device that I had to use to change the springs
https://uploads.tapatalk-cdn.com/201...866b17f7ff.jpg
I think I'm going to modify the tool a little bit to make it easier on my hands.
Once I get all the springs changed today I'm going to read measure my pushrod length cause the 7.100 ones I have may not work. I'll find out and report back later today.
