Originally Posted by
Catmaigne
You have things a little backwards.
From heaviest to lightest... S60, stamped 9", 12 bolt, fabricated 9" = 10 bolt
Most power consumption to least... Stamped or fab 9", S60, 12 bolt, 10 bolt
The weights are generalizations because they depend on your carrier (spool/LSD), axle splines/gun drilling/star flange, and third member (for the 9"). The S60 will be the heaviest and the fab 9" or 10 bolt will be the lightest with all the same bells and whistles. Keeping unsprung weight down is extremely important for autox or road racing. Reducing unsprung weight is second to strength for serious drag.
S60 vs 9"
The strength debate between these two is endless but they will both take a ton of shit (assuming the 9" is built with modern parts and not OE Ford junk from the 50s). The S60 has the bigger ring gear but the 9" has a pilot on the end of the pinion gear.
The S60 is heavier than a stamped 9" and a ton heavier than a fab 9".
The 9" will eat more power because of the offset pinion.
The 9" is typically more expensive.
The 9" has more aftermarket support, gear ratios, and the ability to swap third members on the fly.
If you just need a rear to hold up in a straight line, then get the S60 and save some money. If you want to do that and take corners, then get a 9" (but make sure you get tapered wheel bearings -- the ball bearing ones are for drag cars).
