I know you did. Cause I experience it everyday. To some extent. Probably more so with wide tires.
It was very minor on my camaro, but after having it realigned with a bit of negative camber, it dissappeared.
And that was with the 285s up front.
thank you very much @popo8 for the fans/starter etc. much much appreciated
We'll yeah but lower the car and it changes the geometry. That and wider tires. I was bing sarcastic. Car looks great with thise wheels.
I dont live to work.I work to live
no biggie. I need new rear springs. the rear doesn't sit even side to side for some reason, maybe one is tweaked. other than that I got the slp subframes on, car is instantly stiffer. got the new fan in, now fans work properly, changed oil, oil looked good.
had a helluva scare today on way over @Ltconvert house. the shifter bolts loosened and the shifter stops loosened, car would not go into 1,3,5 or reverse. I thought the trans said screw this I'm out. I'm gonna look for a new shifter, I don't like the b&m that much. I've driven pro 5.0 equipped cars and I liked them.
It doesnt sit even cause when u lower a car, u need an adjustable panhard or else the stock one shoves the rear to one side.
